HP Pavilion x360 15t-br000 RAM Replacement
  1. HP Pavilion x360 15t-br000 RAM Replacement, Keyboard Panel: step 1, image 1 of 3 HP Pavilion x360 15t-br000 RAM Replacement, Keyboard Panel: step 1, image 2 of 3 HP Pavilion x360 15t-br000 RAM Replacement, Keyboard Panel: step 1, image 3 of 3
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 RAM Replacement: step 2, image 1 of 3 HP Pavilion x360 15t-br000 RAM Replacement: step 2, image 2 of 3 HP Pavilion x360 15t-br000 RAM Replacement: step 2, image 3 of 3
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 RAM Replacement, Battery: step 3, image 1 of 1
    • Disconnect the battery cable from the device.
  4. HP Pavilion x360 15t-br000 RAM Replacement: step 4, image 1 of 2 HP Pavilion x360 15t-br000 RAM Replacement: step 4, image 2 of 2
    • Remove the seven Phillips #0 4.5 mm screws.
    • Remove the battery from the device.
  5. HP Pavilion x360 15t-br000 RAM Replacement, Motherboard: step 5, image 1 of 2 HP Pavilion x360 15t-br000 RAM Replacement, Motherboard: step 5, image 2 of 2
    • Disconnect the five cable connections to the motherboard.
  6. HP Pavilion x360 15t-br000 RAM Replacement: step 6, image 1 of 1
    • Unscrew the nine 3mm mounting screws on the motherboard using the Phillips #0 screwdriver.
  7. HP Pavilion x360 15t-br000 RAM Replacement: step 7, image 1 of 2 HP Pavilion x360 15t-br000 RAM Replacement: step 7, image 2 of 2
    • Lift the motherboard carefully then remove the motherboard.
  8. HP Pavilion x360 15t-br000 RAM Replacement, RAM: step 8, image 1 of 1
    • Turn over motherboard and remove the RAM carefully from motherboard.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 342
