HP Pavilion x360 15t-br000 Speakers Replacement
  1. HP Pavilion x360 15t-br000 Speakers Replacement, Keyboard Panel: step 1, image 1 of 3 HP Pavilion x360 15t-br000 Speakers Replacement, Keyboard Panel: step 1, image 2 of 3 HP Pavilion x360 15t-br000 Speakers Replacement, Keyboard Panel: step 1, image 3 of 3
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 Speakers Replacement: step 2, image 1 of 3 HP Pavilion x360 15t-br000 Speakers Replacement: step 2, image 2 of 3 HP Pavilion x360 15t-br000 Speakers Replacement: step 2, image 3 of 3
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 Speakers Replacement, Battery: step 3, image 1 of 1
    • Disconnect the battery cable from the device.
  4. HP Pavilion x360 15t-br000 Speakers Replacement: step 4, image 1 of 2 HP Pavilion x360 15t-br000 Speakers Replacement: step 4, image 2 of 2
    • Remove the seven Phillips #0 4.5 mm screws.
    • Remove the battery from the device.
  5. HP Pavilion x360 15t-br000 Speakers Replacement, Speakers: step 5, image 1 of 3 HP Pavilion x360 15t-br000 Speakers Replacement, Speakers: step 5, image 2 of 3 HP Pavilion x360 15t-br000 Speakers Replacement, Speakers: step 5, image 3 of 3
    • Disconnect the white speaker cable connection from the motherboard.
    • Unscrew the four 3 mm screws mounting the speakers to the laptop using a Phillips #0 screwdriver.
    • Remove the speakers from the laptop.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 121
