Introduction
If your speakers are malfunctioning (no sound or distorted sound), the speakers may need to be replaced. To replace the speakers, you will need to know how to use a screwdriver. Small parts (screws) may be a swallowing hazard for young children; keep all parts in a secure location.
Power off your device and disconnect all external devices connected to the laptop.
Tool used on this step:Heavy-Duty Spudger$4.99
Raising the keyboard, disconnect the first of two cable ribbons with the Heavy-Duty Spudger.
Gently flip up the white plastic lock connecting the ribbon cable to the motherboard.
Use the blue plastic tab on the ribbon cable to disconnect the ribbon cable from the lock.
Remove the screws from the perimeter of the battery with a Phillips 00 Screwdriver.
3 Phillips 2.0 x 4.6 mm screws
Remove the screws from the perimeter of the motherboard with a Phillips 00 Screwdriver.
8 Phillips 2.0 x 4.7 mm screws.
Disconnect the 2 cable ribbons with the Heavy-Duty Spudger.
Use the purple plastic tab on the ribbon cable to disconnect the ribbon cable from the lock.
Disconnect the bundle cable connector by gently gripping the cable wires and pulling outwards.
Remove the screws from the sound piece with a Phillips 00 Screwdriver.
2 Phillips 2.4 x 5.7 mm screws
