HP Pavilion zd8000 Switch Cover Replacement
  1. HP Pavilion zd8000 Switch Cover Replacement, Battery: step 1, image 1 of 1
    • Slide the battery release latch towards you.
  2. HP Pavilion zd8000 Switch Cover Replacement: step 2, image 1 of 2 HP Pavilion zd8000 Switch Cover Replacement: step 2, image 2 of 2
    • Pull up on the battery to remove it.
  3. HP Pavilion zd8000 Switch Cover Replacement, WiFi Card Cables: step 3, image 1 of 2 HP Pavilion zd8000 Switch Cover Replacement, WiFi Card Cables: step 3, image 2 of 2
    • Unscrew the four 8mm Philips screws marked with an icon resembling a stacks of discs.
    • Lift the cover from the right to remove it.
  4. HP Pavilion zd8000 Switch Cover Replacement: step 4, image 1 of 2 HP Pavilion zd8000 Switch Cover Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to detach the grey and black cables connected to the green WiFi card.
  5. HP Pavilion zd8000 Switch Cover Replacement, Switch Cover: step 5, image 1 of 2 HP Pavilion zd8000 Switch Cover Replacement, Switch Cover: step 5, image 2 of 2
    • Place the laptop face-down and rotate it 180 degrees so the vents are facing you.
    • Remove the five 8mm Philips screws. Three are on the black base and two are near the hinges.
  6. HP Pavilion zd8000 Switch Cover Replacement: step 6, image 1 of 1
    • Flip the laptop over.
    • Fully open the laptop.
  7. HP Pavilion zd8000 Switch Cover Replacement: step 7, image 1 of 3 HP Pavilion zd8000 Switch Cover Replacement: step 7, image 2 of 3 HP Pavilion zd8000 Switch Cover Replacement: step 7, image 3 of 3
    • Rotate it so the display is on your right and the keyboard is on your left.
    • Lift the switch cover firmly but slowly so you do not snap it.
    • Lift the switch cover carefully from one end while sliding the spudger between the switch cover and the laptop to separate them.
    • The switch cover should easily separate from the laptop as you run the spudger through.
Allie Menard
820 Reputation
13 Guides authored
Cal Poly, Team 24-56, Amido Spring 2011 Member of Cal Poly, Team 24-56, Amido Spring 2011
CPSU-AMIDO-S11S24G56
4 Members
13 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,109
