HP Pavilion zv5000 Hard Drive Replacement
Eliza Marks
Eliza Marks and 3 other contributors
Last updated on December 22, 2016
3 - 7 minutes
Very easy
Introduction
Go to step 1
Are you having issues saving files to your computer? Have you already tried deleting unwanted files? Replacing the hard drive may solve these issues.
Tools
  1. HP Pavilion zv5000 Hard Drive Replacement, Battery: step 1, image 1 of 1
    • Make sure that your device is properly shut down and unplugged from any outlet.
    • Flip Pavilion over so that the bottom faces up and locate the battery in the bottom left corner.
  2. HP Pavilion zv5000 Hard Drive Replacement: step 2, image 1 of 2 HP Pavilion zv5000 Hard Drive Replacement: step 2, image 2 of 2
    • Press and slide up the battery release tab with your thumb until the battery pops out of place.
  3. HP Pavilion zv5000 Hard Drive Replacement: step 3, image 1 of 2 HP Pavilion zv5000 Hard Drive Replacement: step 3, image 2 of 2
    • Using two fingers, pry the rest of the battery out of the socket.
  4. HP Pavilion zv5000 Hard Drive Replacement, Hard Drive: step 4, image 1 of 2 HP Pavilion zv5000 Hard Drive Replacement, Hard Drive: step 4, image 2 of 2
    • Make sure that the Pavilion is completely powered down and unplugged. Failure to do so may result in an electrical shock.
    • Using the Phillips #0 screwdriver, unscrew the two Phillips PM 2.5X6.0mm screws.
    • The two screws do not come out of the hard drive assembly, they simply disconnect the assembly from the laptop.
  5. HP Pavilion zv5000 Hard Drive Replacement: step 5, image 1 of 2 HP Pavilion zv5000 Hard Drive Replacement: step 5, image 2 of 2
    • Place the spudger underneath the cover of the hard drive and push up gently until the hard drive pops out of place.
    • Completely remove the hard drive from its socket.
    • If the plastic spudger is not sturdy enough to pop the hard drive out of place, try carefully using the metal spudger.
Eliza Marks
649 Reputation
5 Guides authored
UMass Dartmouth, Team 4-6, Catania Fall 2016 Member of UMass Dartmouth, Team 4-6, Catania Fall 2016
UMASSD-CATANIA-F16S4G6
3 Members
5 Guides authored
One Comment
My hp pavilion zx5000 has a blue screen and i am unable to do anything. O. S. Is Windows.
Please help
Danny Morris - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 17
All Time: 3,088
