HP Pavillion dm1-3010nr Cooling Fan Replacement
  1. HP Pavillion dm1-3010nr Cooling Fan Replacement, Battery: step 1, image 1 of 1
    • Flip the device over, so that the bottom cover is exposed.
    • Slide the black locking mechanism into its unlock position.
  2. HP Pavillion dm1-3010nr Cooling Fan Replacement: step 2, image 1 of 1
    • After unlocking the mechanism, slide the battery out of its compartment.
  3. HP Pavillion dm1-3010nr Cooling Fan Replacement, Cooling Fan: step 3, image 1 of 1
    • With the battery removed, the bottom cover can be opened with your hand.
  4. HP Pavillion dm1-3010nr Cooling Fan Replacement: step 4, image 1 of 2 HP Pavillion dm1-3010nr Cooling Fan Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use a screwdriver from your iFixit Toolkit to remove the two 5mm Phillips #0 screws shown in each picture.
    • Use tweezers to carefully remove the fan's power cable from the motherboard. The cable can be seen in the second picture.
  5. HP Pavillion dm1-3010nr Cooling Fan Replacement: step 5, image 1 of 1
    • After removing the screws and unplugging the wire, remove the fan.
Amitpal Gill
375 Reputation
3 Guides authored
UC Davis, Team S7-G1, Lore Fall 2018 Member of UC Davis, Team S7-G1, Lore Fall 2018
UCD-LORE-F18S7G1
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 613
