HP Pavillion dm4t-2100 Memory Card Replacement
  1. HP Pavillion dm4t-2100 Memory Card Replacement, Battery: step 1, image 1 of 2 HP Pavillion dm4t-2100 Memory Card Replacement, Battery: step 1, image 2 of 2
    • Shut down the computer.
    • Shutting down the computer by holding power button can cause damage to computer.
    • Turn computer upside down so the base is facing upward.
  2. HP Pavillion dm4t-2100 Memory Card Replacement: step 2, image 1 of 3 HP Pavillion dm4t-2100 Memory Card Replacement: step 2, image 2 of 3 HP Pavillion dm4t-2100 Memory Card Replacement: step 2, image 3 of 3
    • Slide latch next to battery icon until battery pops up.
    • Pull the battery away from the computer until completely detached.
  3. HP Pavillion dm4t-2100 Memory Card Replacement, Memory Card: step 3, image 1 of 2 HP Pavillion dm4t-2100 Memory Card Replacement, Memory Card: step 3, image 2 of 2
    • Loosen two 5mm Phillips #1 screws securing plastic cover, until cover is detachable.
    • Slide cover toward empty battery area and remove it.
  4. HP Pavillion dm4t-2100 Memory Card Replacement: step 4, image 1 of 2 HP Pavillion dm4t-2100 Memory Card Replacement: step 4, image 2 of 2
    • Lift black cover overlaying memory chip.
    • Spread the tabs on each side of the memory slot to release the module.
    • Remove memory by pulling the memory out at an angle, until completely detached.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 261
