HP ProBook 4320t Keyboard Replacement Guide
  1. HP ProBook 4320t Keyboard Replacement Guide, Battery Removal: step 1, image 1 of 2 HP ProBook 4320t Keyboard Replacement Guide, Battery Removal: step 1, image 2 of 2
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
  2. HP ProBook 4320t Keyboard Replacement Guide, Screws: step 2, image 1 of 2 HP ProBook 4320t Keyboard Replacement Guide, Screws: step 2, image 2 of 2
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
  3. HP ProBook 4320t Keyboard Replacement Guide, Flip: step 3, image 1 of 1
    • Flip laptop over and open it.
  4. HP ProBook 4320t Keyboard Replacement Guide, Push N Lift: step 4, image 1 of 1
    • Slightly push up while lifting up on the power button panel to release the panel.
  5. HP ProBook 4320t Keyboard Replacement Guide, Unscrewing: step 5, image 1 of 1
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
  6. HP ProBook 4320t Keyboard Replacement Guide, Careful Now: step 6, image 1 of 2 HP ProBook 4320t Keyboard Replacement Guide, Careful Now: step 6, image 2 of 2
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
  7. HP ProBook 4320t Keyboard Replacement Guide, Disconnect Wire: step 7, image 1 of 1
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
Joshua
134 Reputation
6 Guides authored
USF Tampa, Team 9-5, Blackwell Fall 2014 Member of USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,102
