HP ProBook 4320t Touchpad Panel Replacement Guide
  1. HP ProBook 4320t Touchpad Panel Replacement Guide, Battery Removal: step 1, image 1 of 2 HP ProBook 4320t Touchpad Panel Replacement Guide, Battery Removal: step 1, image 2 of 2
    • Flip the laptop upside down and remove battery by pressing inward on the two latches holding the battery in.
  2. HP ProBook 4320t Touchpad Panel Replacement Guide, Screws: step 2, image 1 of 2 HP ProBook 4320t Touchpad Panel Replacement Guide, Screws: step 2, image 2 of 2
    • Unscrew the four (2.5 mm Phillips) screws (Use Phillips #0 Screwdriver).
  3. HP ProBook 4320t Touchpad Panel Replacement Guide, Flip: step 3, image 1 of 1
    • Flip laptop over and open it.
  4. HP ProBook 4320t Touchpad Panel Replacement Guide, Push N Lift: step 4, image 1 of 1
    • Slightly push up while lifting up on the power button panel to release the panel.
  5. HP ProBook 4320t Touchpad Panel Replacement Guide, Unscrewing: step 5, image 1 of 1
    • Unscrew the four (2.5 mm Phillips) screws holding the keyboard in (Use Phillips #0 Screwdriver).
  6. HP ProBook 4320t Touchpad Panel Replacement Guide, Careful Now: step 6, image 1 of 2 HP ProBook 4320t Touchpad Panel Replacement Guide, Careful Now: step 6, image 2 of 2
    • Carefully (holding both sides of the keyboard), push up and lift slightly.
    • Keyboard is still connected via a ribbon cable.
    • Move the keyboard slightly to the left to have access to the keyboard ribbon cable.
  7. HP ProBook 4320t Touchpad Panel Replacement Guide, Disconnect Wire: step 7, image 1 of 1
    • Use the black spudger to lift the black latch holding the keyboard ribbon cable.
  8. HP ProBook 4320t Touchpad Panel Replacement Guide, Unscrew: step 8, image 1 of 1
    • Unscrew the three (2.5 mm Phillips) screws holding the bottom touchpad panel.
  9. HP ProBook 4320t Touchpad Panel Replacement Guide, Slide the Panel Off: step 9, image 1 of 1
    • Carefully slide the bottom panel to the right.
    • Keyboard is connected via a wire to the back of the panel.
  10. HP ProBook 4320t Touchpad Panel Replacement Guide, Lift up Carefully: step 10, image 1 of 1
    • Flip the bottom touchpad panel directly towards the screen, being sure to not lift it too high.
    • Keep an eye on the ZIF connector underneath, make sure it is not pulled accidentally.
  11. HP ProBook 4320t Touchpad Panel Replacement Guide, Disconnect Wire: step 11, image 1 of 1
    • Using the black spudger, slightly pry up on the ZIF connector and lift out the wire carefully.
Joshua
134 Reputation
6 Guides authored
USF Tampa, Team 9-5, Blackwell Fall 2014 Member of USF Tampa, Team 9-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G5
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 9
All Time: 487
