HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement
  1. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Battery: step 1, image 1 of 2 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Battery: step 1, image 2 of 2
    • Make sure the laptop is turned off before you start.
    • Push and hold the release tab on the right and left toward the center.
  2. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: step 2, image 1 of 2 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: step 2, image 2 of 2
    • Pull the battery out.
  3. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Backplate: step 3, image 1 of 3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Backplate: step 3, image 2 of 3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Backplate: step 3, image 3 of 3
    • Push and hold the release tabs on the right and left toward the center again.
  4. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: step 4, image 1 of 1
    • Slide the backplate off.
  5. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Hard Disc Drive (HDD): step 5, image 1 of 2 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement, Hard Disc Drive (HDD): step 5, image 2 of 2
    • Locate the hard drive, opposite the battery across from the wireless card.
  6. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: step 6, image 1 of 3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: step 6, image 2 of 3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: step 6, image 3 of 3
    • Remove all four Phillips #00 screws that hold the hard drive in place.
  7. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: step 7, image 1 of 3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: step 7, image 2 of 3 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: step 7, image 3 of 3
    • Lift up on the outer part of the hard drive.
    • Pull the hard drive out.
  8. HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: step 8, image 1 of 2 HP ProBook 440 G1 Hard Disc Drive (HDD) Replacement: step 8, image 2 of 2
    • Remove the four Phillips #00 screws holding the HDD in the HDD cover.
    • The HDD should slide out after all screws are removed.
0 Comments
Past 24 Hours: 6
Past 7 Days: 27
Past 30 Days: 75
All Time: 4,222
