HP ProBook 440 G1 Keyboard Replacement
  1. HP ProBook 440 G1 Keyboard Replacement, Battery: step 1, image 1 of 2 HP ProBook 440 G1 Keyboard Replacement, Battery: step 1, image 2 of 2
    • Make sure the laptop is turned off before you start.
    • Push and hold the release tab on the right and left toward the center.
  2. HP ProBook 440 G1 Keyboard Replacement: step 2, image 1 of 2 HP ProBook 440 G1 Keyboard Replacement: step 2, image 2 of 2
    • Pull the battery out.
  3. HP ProBook 440 G1 Keyboard Replacement, Backplate: step 3, image 1 of 3 HP ProBook 440 G1 Keyboard Replacement, Backplate: step 3, image 2 of 3 HP ProBook 440 G1 Keyboard Replacement, Backplate: step 3, image 3 of 3
    • Push and hold the release tabs on the right and left toward the center again.
  4. HP ProBook 440 G1 Keyboard Replacement: step 4, image 1 of 1
    • Slide the backplate off.
  5. HP ProBook 440 G1 Keyboard Replacement, Keyboard: step 5, image 1 of 2 HP ProBook 440 G1 Keyboard Replacement, Keyboard: step 5, image 2 of 2
    • Locate the two screws on the back of the laptop, holding the keyboard.
    • Remove the two screws using a Phillips #00 screwdriver.
  6. HP ProBook 440 G1 Keyboard Replacement: step 6, image 1 of 1
    • Flip the computer over so as to see the keyboard.
  7. HP ProBook 440 G1 Keyboard Replacement: step 7, image 1 of 2 HP ProBook 440 G1 Keyboard Replacement: step 7, image 2 of 2
    • Place both hands on the keyboard and slide it back.
    • The keyboard will only slide back a small amount.
  8. HP ProBook 440 G1 Keyboard Replacement: step 8, image 1 of 2 HP ProBook 440 G1 Keyboard Replacement: step 8, image 2 of 2
    • Using a plastic opening tool, pull the keyboard up.
  9. HP ProBook 440 G1 Keyboard Replacement: step 9, image 1 of 3 HP ProBook 440 G1 Keyboard Replacement: step 9, image 2 of 3 HP ProBook 440 G1 Keyboard Replacement: step 9, image 3 of 3
    • Locate the connector strip between the keyboard and the laptop.
    • Pull the strip away from the connector until it unplugs.
    • It may take some force to make the strip disconnect.
One Comment
thanks for that
sir i want original keyboard 440 G1
if u dont mine suggest me
karun kumar - Reply
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 26
All Time: 2,258
