HP ProBook 440 G1 Optical Drive Replacement
  1. HP ProBook 440 G1 Optical Drive Replacement, Battery: step 1, image 1 of 2 HP ProBook 440 G1 Optical Drive Replacement, Battery: step 1, image 2 of 2
    • Make sure the laptop is turned off before you start.
    • Push and hold the release tab on the right and left toward the center.
  2. HP ProBook 440 G1 Optical Drive Replacement: step 2, image 1 of 2 HP ProBook 440 G1 Optical Drive Replacement: step 2, image 2 of 2
    • Pull the battery out.
  3. HP ProBook 440 G1 Optical Drive Replacement, Backplate: step 3, image 1 of 3 HP ProBook 440 G1 Optical Drive Replacement, Backplate: step 3, image 2 of 3 HP ProBook 440 G1 Optical Drive Replacement, Backplate: step 3, image 3 of 3
    • Push and hold the release tabs on the right and left toward the center again.
  4. HP ProBook 440 G1 Optical Drive Replacement: step 4, image 1 of 1
    • Slide the backplate off.
  5. HP ProBook 440 G1 Optical Drive Replacement, Optical Drive: step 5, image 1 of 2 HP ProBook 440 G1 Optical Drive Replacement, Optical Drive: step 5, image 2 of 2
    • Locate the optical drive, near the battery on the right side.
  6. HP ProBook 440 G1 Optical Drive Replacement: step 6, image 1 of 3 HP ProBook 440 G1 Optical Drive Replacement: step 6, image 2 of 3 HP ProBook 440 G1 Optical Drive Replacement: step 6, image 3 of 3
    • Remove the Philips PM2.5x6.0 screw that attaches the optical drive to the computer.
  7. HP ProBook 440 G1 Optical Drive Replacement: step 7, image 1 of 2 HP ProBook 440 G1 Optical Drive Replacement: step 7, image 2 of 2
    • Slowly remove the optical drive, by pulling it straight out of the slot.
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 619
