HP ProBook 440 G1 RAM Replacement
  1. HP ProBook 440 G1 RAM Replacement, Battery: step 1, image 1 of 2 HP ProBook 440 G1 RAM Replacement, Battery: step 1, image 2 of 2
    • Make sure the laptop is turned off before you start.
    • Push and hold the release tab on the right and left toward the center.
  2. HP ProBook 440 G1 RAM Replacement: step 2, image 1 of 2 HP ProBook 440 G1 RAM Replacement: step 2, image 2 of 2
    • Pull the battery out.
  3. HP ProBook 440 G1 RAM Replacement, Backplate: step 3, image 1 of 3 HP ProBook 440 G1 RAM Replacement, Backplate: step 3, image 2 of 3 HP ProBook 440 G1 RAM Replacement, Backplate: step 3, image 3 of 3
    • Push and hold the release tabs on the right and left toward the center again.
  4. HP ProBook 440 G1 RAM Replacement: step 4, image 1 of 1
    • Slide the backplate off.
  5. HP ProBook 440 G1 RAM Replacement, RAM: step 5, image 1 of 2 HP ProBook 440 G1 RAM Replacement, RAM: step 5, image 2 of 2
    • Locate the RAM, in the middle of the laptop near the battery.
  6. HP ProBook 440 G1 RAM Replacement: step 6, image 1 of 3 HP ProBook 440 G1 RAM Replacement: step 6, image 2 of 3 HP ProBook 440 G1 RAM Replacement: step 6, image 3 of 3
    • Push the two metal tabs on either side of the RAM stick out.
    • The RAM stick will pop up slightly.
  7. HP ProBook 440 G1 RAM Replacement: step 7, image 1 of 1
    • Remove the RAM stick.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 40
All Time: 2,679
