HP ProBook 450 G3 Hard Drive Replacement
Jingyuan Zhang
Jingyuan Zhang and 3 other contributors
Last updated on January 22, 2020
3 minutes
Easy
Introduction
Go to step 1
This guide will tell you how to replace the hard drive for HP ProBook 450 G3.
  1. HP ProBook 450 G3 Hard Drive Replacement, Hard Drive: step 1, image 1 of 3 HP ProBook 450 G3 Hard Drive Replacement, Hard Drive: step 1, image 2 of 3 HP ProBook 450 G3 Hard Drive Replacement, Hard Drive: step 1, image 3 of 3
    • The screw will not come out, after you unscrew it.
    • Unscrew the 2.5 mm screw with PH00 screwdriver.
    • Pull the cover off the computer using two hands.
  2. HP ProBook 450 G3 Hard Drive Replacement: step 2, image 1 of 1
    • Unscrew the all four 2.5 mm screws with the PH00 screwdriver.
    • Then carefully pull to the right the hard-drive. It should release from its container.
2 other people completed this guide.
Jingyuan Zhang
661 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 35
All Time: 11,146
