HP ProBook 450 G4 Battery Replacement
  1. HP ProBook 450 G4 Battery Replacement, Hard Drive: step 1, image 1 of 2 HP ProBook 450 G4 Battery Replacement, Hard Drive: step 1, image 2 of 2
    • Power your laptop off.
    • Flip the laptop over.
    • Orient the laptop so the two vents on the bottom face upward and are further away from you.
  2. HP ProBook 450 G4 Battery Replacement: step 2, image 1 of 3 HP ProBook 450 G4 Battery Replacement: step 2, image 2 of 3 HP ProBook 450 G4 Battery Replacement: step 2, image 3 of 3
    • Use the Phillips #0 screwdriver to remove the 6.8 mm screw that secures the vent panel to the laptop.
    • Use the spudger to separate the vent panel from the laptop.
    • Slide the vent panel off the backside of the laptop.
  3. HP ProBook 450 G4 Battery Replacement: step 3, image 1 of 2 HP ProBook 450 G4 Battery Replacement: step 3, image 2 of 2
    • Use the Phillips #0 screwdriver to remove the black 3.2mm screw that secures the hard drive to the left side of the laptop.
  4. HP ProBook 450 G4 Battery Replacement: step 4, image 1 of 2 HP ProBook 450 G4 Battery Replacement: step 4, image 2 of 2
    • Use the spudger to lift the left side of the hard drive up.
    • Pull the hard drive diagonally to the left to release the hard drive from the laptop.
  5. HP ProBook 450 G4 Battery Replacement, Keyboard: step 5, image 1 of 3 HP ProBook 450 G4 Battery Replacement, Keyboard: step 5, image 2 of 3 HP ProBook 450 G4 Battery Replacement, Keyboard: step 5, image 3 of 3
    • Remove the 6.6mm T8 Torx screw located below where the hard drive used to be.
    • Remove the 6.6mm T8 Torx screw located below and to the left of the circular, silver and black fan.
  6. HP ProBook 450 G4 Battery Replacement: step 6, image 1 of 3 HP ProBook 450 G4 Battery Replacement: step 6, image 2 of 3 HP ProBook 450 G4 Battery Replacement: step 6, image 3 of 3
    • Use the spudger to press down on the two black tabs that are underneath where the hard drive used to be.
    • Apply pressure to the black tabs until they release and pop out.
  7. HP ProBook 450 G4 Battery Replacement: step 7, image 1 of 3 HP ProBook 450 G4 Battery Replacement: step 7, image 2 of 3 HP ProBook 450 G4 Battery Replacement: step 7, image 3 of 3
    • Orient the laptop so the keyboard is facing upwards and towards you.
    • Insert the spudger in between the edge of the keyboard and the computer frame.
    • Slide the spudger around the edge of the keyboard until the keyboard is loose.
    • Gently pull the keyboard away from the body of the laptop.
    • Do not pull the keyboard all the way off because there is still a connector cable underneath that needs to be disconnected.
  8. HP ProBook 450 G4 Battery Replacement: step 8, image 1 of 2 HP ProBook 450 G4 Battery Replacement: step 8, image 2 of 2
    • Use a spudger to gently lift up the black locking bar on the keyboard connector.
    • Slide the keyboard ribbon out of the connector.
    • Remove the keyboard.
    • To re-attach the keyboard ribbon, slide it into the connector and swing the locking bar down.
  9. HP ProBook 450 G4 Battery Replacement, Battery: step 9, image 1 of 2 HP ProBook 450 G4 Battery Replacement, Battery: step 9, image 2 of 2
    • Flip the laptop back over.
    • Remove the eight 6.8mm T8 Torx screws on the backside of the laptop.
  10. HP ProBook 450 G4 Battery Replacement: step 10, image 1 of 2 HP ProBook 450 G4 Battery Replacement: step 10, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the three 6.6mm screws from the upper left corner of the laptop.
  11. HP ProBook 450 G4 Battery Replacement: step 11, image 1 of 2 HP ProBook 450 G4 Battery Replacement: step 11, image 2 of 2
    • Use the spudger to slide the disk drive out of the laptop.
    • Use the Phillips #0 screwdriver to remove the two 3.2mm screws that are underneath where the disk drive previously was.
  12. HP ProBook 450 G4 Battery Replacement: step 12, image 1 of 3 HP ProBook 450 G4 Battery Replacement: step 12, image 2 of 3 HP ProBook 450 G4 Battery Replacement: step 12, image 3 of 3
    • Use a Phillips #0 screwdriver to remove the two 6.6mm screws.
  13. HP ProBook 450 G4 Battery Replacement: step 13, image 1 of 2 HP ProBook 450 G4 Battery Replacement: step 13, image 2 of 2
    • Flip the laptop back over so it is facing upwards.
    • Remove the six 6.6mm T8 Torx screws underneath where the keyboard used to be.
  14. HP ProBook 450 G4 Battery Replacement: step 14, image 1 of 3 HP ProBook 450 G4 Battery Replacement: step 14, image 2 of 3 HP ProBook 450 G4 Battery Replacement: step 14, image 3 of 3
    • Use the spudger to disconnect the nine cable connectors that secure the top case of the laptop to the body of the laptop.
    • Be extra careful while disconnecting the cable connectors because they can tear easily.
  15. HP ProBook 450 G4 Battery Replacement: step 15, image 1 of 2 HP ProBook 450 G4 Battery Replacement: step 15, image 2 of 2
    • Insert the spudger in between the top case of the laptop and its outer frame.
    • Slide the spudger around the edge of the laptop until the top case comes off.
    • Remove the top case.
  16. HP ProBook 450 G4 Battery Replacement: step 16, image 1 of 2 HP ProBook 450 G4 Battery Replacement: step 16, image 2 of 2
    • Insert the opening tool underneath the left side of the battery to remove it from the laptop.
8 other people completed this guide.
Sebastian Dow
1,007 Reputation
6 Guides authored
Cal Poly, Team S1-G3, White Winter 2020 Member of Cal Poly, Team S1-G3, White Winter 2020
CPSU-WHITE-W20S1G3
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 12
Past 7 Days: 58
Past 30 Days: 367
All Time: 18,253
