HP ProBook 450 G4 Hard Drive Replacement
  1. HP ProBook 450 G4 Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 HP ProBook 450 G4 Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Power your laptop off.
    • Flip the laptop over.
    • Orient the laptop so the two vents on the bottom face upward and are further away from you.
  2. HP ProBook 450 G4 Hard Drive Replacement: step 2, image 1 of 3 HP ProBook 450 G4 Hard Drive Replacement: step 2, image 2 of 3 HP ProBook 450 G4 Hard Drive Replacement: step 2, image 3 of 3
    • Use the Phillips #0 screwdriver to remove the 6.8 mm screw that secures the vent panel to the laptop.
    • Use the spudger to separate the vent panel from the laptop.
    • Slide the vent panel off the backside of the laptop.
  3. HP ProBook 450 G4 Hard Drive Replacement: step 3, image 1 of 2 HP ProBook 450 G4 Hard Drive Replacement: step 3, image 2 of 2
    • Use the Phillips #0 screwdriver to remove the black 3.2mm screw that secures the hard drive to the left side of the laptop.
  4. HP ProBook 450 G4 Hard Drive Replacement: step 4, image 1 of 2 HP ProBook 450 G4 Hard Drive Replacement: step 4, image 2 of 2
    • Use the spudger to lift the left side of the hard drive up.
    • Pull the hard drive diagonally to the left to release the hard drive from the laptop.
Sebastian Dow
1,007 Reputation
6 Guides authored
Cal Poly, Team S1-G3, White Winter 2020 Member of Cal Poly, Team S1-G3, White Winter 2020
CPSU-WHITE-W20S1G3
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 119
All Time: 3,612
