HP ProBook 450 G4 Keyboard Replacement
  1. HP ProBook 450 G4 Keyboard Replacement, Hard Drive: step 1, image 1 of 2 HP ProBook 450 G4 Keyboard Replacement, Hard Drive: step 1, image 2 of 2
    • Power your laptop off.
    • Flip the laptop over.
    • Orient the laptop so the two vents on the bottom face upward and are further away from you.
  2. HP ProBook 450 G4 Keyboard Replacement: step 2, image 1 of 3 HP ProBook 450 G4 Keyboard Replacement: step 2, image 2 of 3 HP ProBook 450 G4 Keyboard Replacement: step 2, image 3 of 3
    • Use the Phillips #0 screwdriver to remove the 6.8 mm screw that secures the vent panel to the laptop.
    • Use the spudger to separate the vent panel from the laptop.
    • Slide the vent panel off the backside of the laptop.
  3. HP ProBook 450 G4 Keyboard Replacement: step 3, image 1 of 2 HP ProBook 450 G4 Keyboard Replacement: step 3, image 2 of 2
    • Use the Phillips #0 screwdriver to remove the black 3.2mm screw that secures the hard drive to the left side of the laptop.
  4. HP ProBook 450 G4 Keyboard Replacement: step 4, image 1 of 2 HP ProBook 450 G4 Keyboard Replacement: step 4, image 2 of 2
    • Use the spudger to lift the left side of the hard drive up.
    • Pull the hard drive diagonally to the left to release the hard drive from the laptop.
  5. HP ProBook 450 G4 Keyboard Replacement, Keyboard: step 5, image 1 of 3 HP ProBook 450 G4 Keyboard Replacement, Keyboard: step 5, image 2 of 3 HP ProBook 450 G4 Keyboard Replacement, Keyboard: step 5, image 3 of 3
    • Remove the 6.6mm T8 Torx screw located below where the hard drive used to be.
    • Remove the 6.6mm T8 Torx screw located below and to the left of the circular, silver and black fan.
  6. HP ProBook 450 G4 Keyboard Replacement: step 6, image 1 of 3 HP ProBook 450 G4 Keyboard Replacement: step 6, image 2 of 3 HP ProBook 450 G4 Keyboard Replacement: step 6, image 3 of 3
    • Use the spudger to press down on the two black tabs that are underneath where the hard drive used to be.
    • Apply pressure to the black tabs until they release and pop out.
  7. HP ProBook 450 G4 Keyboard Replacement: step 7, image 1 of 3 HP ProBook 450 G4 Keyboard Replacement: step 7, image 2 of 3 HP ProBook 450 G4 Keyboard Replacement: step 7, image 3 of 3
    • Orient the laptop so the keyboard is facing upwards and towards you.
    • Insert the spudger in between the edge of the keyboard and the computer frame.
    • Slide the spudger around the edge of the keyboard until the keyboard is loose.
    • Gently pull the keyboard away from the body of the laptop.
    • Do not pull the keyboard all the way off because there is still a connector cable underneath that needs to be disconnected.
  8. HP ProBook 450 G4 Keyboard Replacement: step 8, image 1 of 2 HP ProBook 450 G4 Keyboard Replacement: step 8, image 2 of 2
    • Use a spudger to gently lift up the black locking bar on the keyboard connector.
    • Slide the keyboard ribbon out of the connector.
    • Remove the keyboard.
    • To re-attach the keyboard ribbon, slide it into the connector and swing the locking bar down.
3 other people completed this guide.
Sebastian Dow
1,112 Reputation
6 Guides authored
Cal Poly, Team S1-G3, White Winter 2020 Member of Cal Poly, Team S1-G3, White Winter 2020
CPSU-WHITE-W20S1G3
4 Members
18 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 34
Past 30 Days: 118
All Time: 9,295
