Introduction
If your HP ProBook 4520s shuts down without warning, you may have a hard drive error and need to replace the hard drive.
Flip the 4520s upside-down with the front toward you.
Push the two latches below the battery inwards at the same time.
Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
Use a Phillips #1 screwdriver to remove the two 7mm screws located on either side of the keyboard panel.
Use a Phillips #1 screwdriver to remove the three 3mm screws along the top of the palm rest.
The hard drive is contained in the housing on the lower right.
Remove two 5mm screws on the left using a Phillips #1 screwdriver.
Fully loosen the captive screw on the right using a Phillips #1 screwdriver.
53 other people completed this guide.
5 Comments
is it 2.5" HDD ?
Yes. I should have included that.
Thank you so much lol
You taught me that i didn’t have to throw and break this darn machine to get the hard drive out :P
M
Thank you!
This guide works well for the 4320s as well, though there are a few small differences.
The battery compartment has 4 screws and there are none on the back.
The keyboard is held by 4 screws.
The touchpad has the same type of connector as the keyboard.
The hard drive cage is held by a #1 Philips and two #0 Philips instead of #1.
