HP ProBook 4520s Optical Drive Replacement
  1. HP ProBook 4520s Optical Drive Replacement, Battery: step 1, image 1 of 2 HP ProBook 4520s Optical Drive Replacement, Battery: step 1, image 2 of 2
    • Flip the 4520s upside-down with the front toward you.
    • Push the two latches below the battery inwards at the same time.
  2. HP ProBook 4520s Optical Drive Replacement: step 2, image 1 of 1
    • Remove the battery by holding the latches and sliding the battery away from you.
  3. HP ProBook 4520s Optical Drive Replacement, Switch Cover: step 3, image 1 of 2 HP ProBook 4520s Optical Drive Replacement, Switch Cover: step 3, image 2 of 2
    • Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
  4. HP ProBook 4520s Optical Drive Replacement: step 4, image 1 of 2 HP ProBook 4520s Optical Drive Replacement: step 4, image 2 of 2
    • Flip the 4520s over and rotate it so the back is facing you.
    • Use a metal spudger to peel off two rubber caps located on either side of the battery port.
  5. HP ProBook 4520s Optical Drive Replacement: step 5, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
  6. HP ProBook 4520s Optical Drive Replacement: step 6, image 1 of 3 HP ProBook 4520s Optical Drive Replacement: step 6, image 2 of 3 HP ProBook 4520s Optical Drive Replacement: step 6, image 3 of 3
    • Rotate the 4520s and then open it with the screen facing you.
    • The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
    • Lift the switch cover away from the 4520s and set it aside.
  7. HP ProBook 4520s Optical Drive Replacement, Keyboard: step 7, image 1 of 2 HP ProBook 4520s Optical Drive Replacement, Keyboard: step 7, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the two 7mm screws located on either side of the keyboard panel.
  8. HP ProBook 4520s Optical Drive Replacement: step 8, image 1 of 1
    • Slide the keyboard panel away from you to free it from the 4520s.
    • Do not yank the keyboard panel away from the 4520s. This may damage the cable.
  9. HP ProBook 4520s Optical Drive Replacement: step 9, image 1 of 2 HP ProBook 4520s Optical Drive Replacement: step 9, image 2 of 2
    • Gently raise up the keyboard and flip it over to reveal a ribbon cable.
    • Release the ribbon cable by carefully lifting the black tab upwards, one side at a time.
    • Remove the cable and lift the keyboard panel up. Set it aside.
    • When reassembling, feed the ribbon cable into the port. Press down on the tab to pinch the cable in place.
  10. HP ProBook 4520s Optical Drive Replacement, Optical Drive: step 10, image 1 of 2 HP ProBook 4520s Optical Drive Replacement, Optical Drive: step 10, image 2 of 2
    • The housing for the optical drive is on the right of the device.
    • Remove the 5mm screw on the left side of the metal plate with a Phillips (PH1) head screwdriver.
  11. HP ProBook 4520s Optical Drive Replacement: step 11, image 1 of 1
    • Use a metal spudger to push the optical drive to the right and partially out of the casing.
  12. HP ProBook 4520s Optical Drive Replacement: step 12, image 1 of 1
    • Slide the optical drive outward from the 4520s.
  13. HP ProBook 4520s Optical Drive Replacement: step 13, image 1 of 2 HP ProBook 4520s Optical Drive Replacement: step 13, image 2 of 2
    • Use a Phillips (PH1) head screwdriver to remove two 2mm screws securing the metal tab to the optical drive.
Nicholas Caruso
311 Reputation
1 Guide authored
UC Davis, Team 1-3, Oliver Fall 2016 Member of UC Davis, Team 1-3, Oliver Fall 2016
UCD-OLIVER-F16S1G3
5 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 17
All Time: 2,400
