HP ProBook 4520s Screen Replacement
Robert Spencer Harrison
Robert Spencer Harrison and 5 other contributors
Last updated on December 16, 2016
30 - 45 minutes
Moderate
Introduction
Go to step 1
If your laptop screen is cracked or appears dark while the computer is running, replace the screen.
Tools
Show more…
  1. HP ProBook 4520s Screen Replacement, Battery: step 1, image 1 of 2 HP ProBook 4520s Screen Replacement, Battery: step 1, image 2 of 2
    • Flip the 4520s upside-down with the front toward you.
    • Push the two latches below the battery inwards at the same time.
  2. HP ProBook 4520s Screen Replacement: step 2, image 1 of 1
    • Remove the battery by holding the latches and sliding the battery away from you.
  3. HP ProBook 4520s Screen Replacement, Switch Cover: step 3, image 1 of 2 HP ProBook 4520s Screen Replacement, Switch Cover: step 3, image 2 of 2
    • Use a Phillips #1 screwdriver to remove three 2mm screws where the battery was located.
  4. HP ProBook 4520s Screen Replacement: step 4, image 1 of 2 HP ProBook 4520s Screen Replacement: step 4, image 2 of 2
    • Flip the 4520s over and rotate it so the back is facing you.
    • Use a metal spudger to peel off two rubber caps located on either side of the battery port.
  5. HP ProBook 4520s Screen Replacement: step 5, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the 3mm screws behind the caps.
  6. HP ProBook 4520s Screen Replacement: step 6, image 1 of 3 HP ProBook 4520s Screen Replacement: step 6, image 2 of 3 HP ProBook 4520s Screen Replacement: step 6, image 3 of 3
    • Rotate the 4520s and then open it with the screen facing you.
    • The switch cover is located above the keyboard. Push the switch cover away from you until it comes loose from the 4520s.
    • Lift the switch cover away from the 4520s and set it aside.
  7. HP ProBook 4520s Screen Replacement, Screen: step 7, image 1 of 2 HP ProBook 4520s Screen Replacement, Screen: step 7, image 2 of 2
    • Use a metal spudger to remove four rubber caps at the bottom of the screen border.
  8. HP ProBook 4520s Screen Replacement: step 8, image 1 of 2 HP ProBook 4520s Screen Replacement: step 8, image 2 of 2
    • Use a Torx (T9) head screwdriver to remove the four 5mm screws beneath the rubber caps.
  9. HP ProBook 4520s Screen Replacement: step 9, image 1 of 3 HP ProBook 4520s Screen Replacement: step 9, image 2 of 3 HP ProBook 4520s Screen Replacement: step 9, image 3 of 3
    • Pry open the tabs behind the border of the screen using a metal spudger.
    • Set the border of the screen aside.
  10. HP ProBook 4520s Screen Replacement: step 10, image 1 of 2 HP ProBook 4520s Screen Replacement: step 10, image 2 of 2
    • Use a Torx (T9) head screwdriver to remove two 5mm screws above the screen, and two more screws below it.
    • The bottom set of screws is installed on the innermost screw holes.
  11. HP ProBook 4520s Screen Replacement: step 11, image 1 of 1
    • Above the screen is a bronze port with a cable connected to it. Disconnect the cable using a metal spudger or your finger.
  12. HP ProBook 4520s Screen Replacement: step 12, image 1 of 1
    • Gently push the back cover away.
  13. HP ProBook 4520s Screen Replacement: step 13, image 1 of 3 HP ProBook 4520s Screen Replacement: step 13, image 2 of 3 HP ProBook 4520s Screen Replacement: step 13, image 3 of 3
    • Use a Phillips (PH1) head screwdriver to remove eight 2mm screws from the screen. Four of the screws will be on the left side and four will be on the right.
    • Place the screen face down.
  14. HP ProBook 4520s Screen Replacement: step 14, image 1 of 3 HP ProBook 4520s Screen Replacement: step 14, image 2 of 3 HP ProBook 4520s Screen Replacement: step 14, image 3 of 3
    • Peel the ribbon cable away from the screen.
  15. HP ProBook 4520s Screen Replacement: step 15, image 1 of 2 HP ProBook 4520s Screen Replacement: step 15, image 2 of 2
    • To open the clamp for the ribbon cable, use a spudger to pry up the metal bar securing it to the screen.
    • Disconnect the cable after freeing it from the metal bar
6 other people completed this guide.
1,353 Reputation
4 Guides authored
UC Davis, Team 1-3, Oliver Fall 2016 Member of UC Davis, Team 1-3, Oliver Fall 2016
UCD-OLIVER-F16S1G3
5 Members
8 Guides authored
2 Comments
I need back cover hp i5 probook 4520s
amir86216 - Reply
I need speakers hp probook 4520s i5
Osagie Rmd - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 6,373
