HP ProBook 4530s Hard Drive Replacement
  1. HP ProBook 4530s Hard Drive Replacement, Introduction: step 1, image 1 of 2 HP ProBook 4530s Hard Drive Replacement, Introduction: step 1, image 2 of 2
    • Start by flipping over the laptop onto its back.
  2. HP ProBook 4530s Hard Drive Replacement, Battery Removal: step 2, image 1 of 2 HP ProBook 4530s Hard Drive Replacement, Battery Removal: step 2, image 2 of 2
    • Press inward on the two switches.
    • The battery should pop out slightly.
    • Remove the battery.
  3. HP ProBook 4530s Hard Drive Replacement, Back Panel Removal: step 3, image 1 of 2 HP ProBook 4530s Hard Drive Replacement, Back Panel Removal: step 3, image 2 of 2
    • Press inward on both switches while pushing the center panel away from you. It should slide slightly backwards.
    • Release the switches.
    • Slide the panel the rest of the way out.
  4. HP ProBook 4530s Hard Drive Replacement, Removing HDD: step 4, image 1 of 2 HP ProBook 4530s Hard Drive Replacement, Removing HDD: step 4, image 2 of 2
    • Unscrew the four screws located on the edges of the base.
    • Lift enough on the right side of the HDD to make it over the plastic paneling.
    • Pull outward.
  5. HP ProBook 4530s Hard Drive Replacement, Removing HDD from Base: step 5, image 1 of 3 HP ProBook 4530s Hard Drive Replacement, Removing HDD from Base: step 5, image 2 of 3 HP ProBook 4530s Hard Drive Replacement, Removing HDD from Base: step 5, image 3 of 3
    • Remove the adhesive from the protective covering over the HDD.
    • Remove the four screws around the edges of the metal base.
    • Pull out the HDD from the base.
  6. HP ProBook 4530s Hard Drive Replacement, Conclusion: step 6, image 1 of 1
    • Insert the new HDD or SSD.
9 other people completed this guide.
Drew Canada
1,490 Reputation
4 Guides authored
2 Guide Comments
Clear and easy instructions. It’s nice to encounter a computer with such easy access to the internals.
Lensyl Urbano - Reply Share
You have saved me time and money from going to my engineer to help me out. Thank you.
Mercy Ayinde - Reply Share
Past 24 Hours: 10
Past 7 Days: 45
Past 30 Days: 154
All Time: 14,330
