HP ProBook 4540s Optical Drive Replacement
  1. HP ProBook 4540s Optical Drive Replacement, Battery: step 1, image 1 of 1
    • Make sure the computer is shut off and the power cord is unplugged from the AC outlet.
    • Slide the two release latches on either side of the battery.
    • Gently tilt the battery upward and remove it from its socket.
  2. HP ProBook 4540s Optical Drive Replacement, Bottom Door: step 2, image 1 of 1
    • Turn the computer so the bottom is facing towards you.
    • Remove the one 3.0 mm Phillips PM2.0x3.0 security screw.
    • The security screw is an optional feature and isn't required to hold the backing if there is not one screwed in place.
    • Slide the release latches then pull the door towards you. Lift the door away to completely remove it.
  3. HP ProBook 4540s Optical Drive Replacement, Optical/CD Drive: step 3, image 1 of 2 HP ProBook 4540s Optical Drive Replacement, Optical/CD Drive: step 3, image 2 of 2
    • Remove one 6.0 mm Phillips PM2.5x6.0 screw that is securing the optical drive.
  4. HP ProBook 4540s Optical Drive Replacement: step 4, image 1 of 2 HP ProBook 4540s Optical Drive Replacement: step 4, image 2 of 2
    • Press the optical drive tab to release the drive component.
    • Gently pull and remove the component from the computer.
3 other people completed this guide.
Amber Schindler
1,057 Reputation
6 Guides authored
UW Tacoma, Team 1-5, Rose Fall 2016 Member of UW Tacoma, Team 1-5, Rose Fall 2016
UWT-ROSE-F16S1G5
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 24
All Time: 2,651
