HP ProBook 650 G4 Keyboard Replacement
  1. HP ProBook 650 G4 Keyboard Replacement, Remove Back Plate: step 1, image 1 of 1
    • Loosen the 8 Philips screws circled in red in the photo. These screws are captive and should not come out fully.
    • Use pry tool starting at one of the hinges to release the clips all around the back plate
    • Remove plate and set aside.
  2. HP ProBook 650 G4 Keyboard Replacement, Releasing Keyboard: step 2, image 1 of 3 HP ProBook 650 G4 Keyboard Replacement, Releasing Keyboard: step 2, image 2 of 3 HP ProBook 650 G4 Keyboard Replacement, Releasing Keyboard: step 2, image 3 of 3
    • Unscrew the 3 Philips screws by the keyboard icons. (Circled in red)
    • The screws are captive and should not be removed fully.
    • Open the laptop screen
    • Use keyboard removal tool to push out the keyboard (circled in green)
    • anything that fits in the hole could be used if tool not available.
  3. HP ProBook 650 G4 Keyboard Replacement, Releasing keyboard: step 3, image 1 of 2 HP ProBook 650 G4 Keyboard Replacement, Releasing keyboard: step 3, image 2 of 2
    • Work around the keyboard releasing the clips.
    • Clips are only located on the top, left, and right of the keyboard.
    • flip the keyboard towards the mouse pad taking care not to damage the ribbon cables.
  4. HP ProBook 650 G4 Keyboard Replacement, Release Ribbon Cables: step 4, image 1 of 3 HP ProBook 650 G4 Keyboard Replacement, Release Ribbon Cables: step 4, image 2 of 3 HP ProBook 650 G4 Keyboard Replacement, Release Ribbon Cables: step 4, image 3 of 3
    • with a plastic spudger tool flip up the black clips to release the ribbon cables
    • Gently pull out the cables, there should be no resistance if the clips were opened properly.
    • There may be some adhesive connecting the cable to the keyboard (green arrow).
  5. HP ProBook 650 G4 Keyboard Replacement, Install New Ribbon Cables: step 5, image 1 of 2 HP ProBook 650 G4 Keyboard Replacement, Install New Ribbon Cables: step 5, image 2 of 2
    • Gently fold the new ribbon cables at the 15B line
    • Gently push in the ribbon cables and press down the black clips.
    • Make sure that the cables are pushed in far enough. They have a line marking how far they should be inserted.
    • Slide in the bottom clips of the keyboard and flip towards the screen
    • Push the keyboard all around until all of the clips click into place.
  6. HP ProBook 650 G4 Keyboard Replacement, Reassemble Laptop: step 6, image 1 of 2 HP ProBook 650 G4 Keyboard Replacement, Reassemble Laptop: step 6, image 2 of 2
    • Screw in the 3 keyboard screws
    • Push the back plate on and screw in the 8 screws
    • Go around the back plate making sure that it is clipped in all around.
David Salerno
823 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 84
All Time: 2,328
