HP ProBook x360 11 G5 EE Display Panel Replacement
Michelle Pina
Michelle Pina and one other contributor
Last updated on December 27, 2021
20 - 45 minutes
Moderate
Better Introduction
Introduction
Go to step 1
In the guide, we will be covering how to replace the touchscreen display panel of an HP ProBook x360 11 G5 Education Edition. The display of a laptop is vital to a user since it allows them to perform the software functions they need.
Tools
Show more…
  1. HP ProBook x360 11 G5 EE Display Panel Replacement, Keyboard Assembly: step 1, image 1 of 3 HP ProBook x360 11 G5 EE Display Panel Replacement, Keyboard Assembly: step 1, image 2 of 3 HP ProBook x360 11 G5 EE Display Panel Replacement, Keyboard Assembly: step 1, image 3 of 3
    • Remove the 4.1 mm screws with a T5 Torx screwdriver.
    • Remove the 4.1 mm screws using a JIS #0 screwdriver.
  2. HP ProBook x360 11 G5 EE Display Panel Replacement: step 2, image 1 of 1
    • Use an opening pick to pry the corners of the keyboard deck.
  3. HP ProBook x360 11 G5 EE Display Panel Replacement: step 3, image 1 of 3 HP ProBook x360 11 G5 EE Display Panel Replacement: step 3, image 2 of 3 HP ProBook x360 11 G5 EE Display Panel Replacement: step 3, image 3 of 3
    • Use an opening pick or opening tool to pry around the sides of the keyboard assembly.
  4. HP ProBook x360 11 G5 EE Display Panel Replacement: step 4, image 1 of 3 HP ProBook x360 11 G5 EE Display Panel Replacement: step 4, image 2 of 3 HP ProBook x360 11 G5 EE Display Panel Replacement: step 4, image 3 of 3
    • Lift the keyboard assembly to expose two ribbon cables.
    • Lift the two plastic tabs that hold the cables in place on the motherboard
    • Slide the ribbon cables out of each connector.
  5. HP ProBook x360 11 G5 EE Display Panel Replacement: step 5, image 1 of 2 HP ProBook x360 11 G5 EE Display Panel Replacement: step 5, image 2 of 2
    • Remove the keyboard assembly from the rest of the computer.
  6. HP ProBook x360 11 G5 EE Display Panel Replacement, Battery: step 6, image 1 of 2 HP ProBook x360 11 G5 EE Display Panel Replacement, Battery: step 6, image 2 of 2
    • Remove the four 3 mm screws from the battery with the JIS #0 screwdriver.
  7. HP ProBook x360 11 G5 EE Display Panel Replacement: step 7, image 1 of 3 HP ProBook x360 11 G5 EE Display Panel Replacement: step 7, image 2 of 3 HP ProBook x360 11 G5 EE Display Panel Replacement: step 7, image 3 of 3
    • Pry the battery up from the laptop using an opening pick.
    • Lift the battery out of its place.
  8. HP ProBook x360 11 G5 EE Display Panel Replacement, Display Panel: step 8, image 1 of 3 HP ProBook x360 11 G5 EE Display Panel Replacement, Display Panel: step 8, image 2 of 3 HP ProBook x360 11 G5 EE Display Panel Replacement, Display Panel: step 8, image 3 of 3
    • Use the opening pick and metal spudger to pry open the display cover.
  9. HP ProBook x360 11 G5 EE Display Panel Replacement: step 9, image 1 of 2 HP ProBook x360 11 G5 EE Display Panel Replacement: step 9, image 2 of 2
    • Remove the ribbon wire that is attached to the display cover to fully detach it.
  10. HP ProBook x360 11 G5 EE Display Panel Replacement: step 10, image 1 of 2 HP ProBook x360 11 G5 EE Display Panel Replacement: step 10, image 2 of 2
    • Remove the four 2.3 mm screws holding the screen in place with the JIS #0 screwdriver.
  11. HP ProBook x360 11 G5 EE Display Panel Replacement: step 11, image 1 of 3 HP ProBook x360 11 G5 EE Display Panel Replacement: step 11, image 2 of 3 HP ProBook x360 11 G5 EE Display Panel Replacement: step 11, image 3 of 3
    • Lift the screen to disconnect the wire attaching it to the laptop.
    • Remove the display panel from the rest of the laptop.
2 other people completed this guide.
Michelle Pina
506 Reputation
4 Guides authored
Gateway, Team 1-4, Pee Fall 2021 Member of Gateway, Team 1-4, Pee Fall 2021
GCC-PEE-F21S1G4
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 87
All Time: 3,137
