HP ProBook x360 11 G5 EE Speakers Replacement
Michelle Pina
Michelle Pina and 2 other contributors
Last updated on December 27, 2021
10 - 20 minutes
Easy
Introduction
Go to step 1
In the guide, we are instructing how to replace the speakers from an HP ProBook x360 11 G5 EE. The speakers are essential to generate sound from the laptop. For this laptop, the audio is distorted; therefore, the speakers need to be replaced.
Tools
Show more…
  1. HP ProBook x360 11 G5 EE Speakers Replacement, Keyboard Assembly: step 1, image 1 of 3 HP ProBook x360 11 G5 EE Speakers Replacement, Keyboard Assembly: step 1, image 2 of 3 HP ProBook x360 11 G5 EE Speakers Replacement, Keyboard Assembly: step 1, image 3 of 3
    • Remove the 4.1 mm screws with a T5 Torx screwdriver.
    • Remove the 4.1 mm screws using a JIS #0 screwdriver.
  2. HP ProBook x360 11 G5 EE Speakers Replacement: step 2, image 1 of 1
    • Use an opening pick to pry the corners of the keyboard deck.
  3. HP ProBook x360 11 G5 EE Speakers Replacement: step 3, image 1 of 3 HP ProBook x360 11 G5 EE Speakers Replacement: step 3, image 2 of 3 HP ProBook x360 11 G5 EE Speakers Replacement: step 3, image 3 of 3
    • Use an opening pick or opening tool to pry around the sides of the keyboard assembly.
  4. HP ProBook x360 11 G5 EE Speakers Replacement: step 4, image 1 of 3 HP ProBook x360 11 G5 EE Speakers Replacement: step 4, image 2 of 3 HP ProBook x360 11 G5 EE Speakers Replacement: step 4, image 3 of 3
    • Lift the keyboard assembly to expose two ribbon cables.
    • Lift the two plastic tabs that hold the cables in place on the motherboard
    • Slide the ribbon cables out of each connector.
  5. HP ProBook x360 11 G5 EE Speakers Replacement: step 5, image 1 of 2 HP ProBook x360 11 G5 EE Speakers Replacement: step 5, image 2 of 2
    • Remove the keyboard assembly from the rest of the computer.
  6. HP ProBook x360 11 G5 EE Speakers Replacement, Battery: step 6, image 1 of 2 HP ProBook x360 11 G5 EE Speakers Replacement, Battery: step 6, image 2 of 2
    • Remove the four 3 mm screws from the battery with the JIS #0 screwdriver.
  7. HP ProBook x360 11 G5 EE Speakers Replacement: step 7, image 1 of 3 HP ProBook x360 11 G5 EE Speakers Replacement: step 7, image 2 of 3 HP ProBook x360 11 G5 EE Speakers Replacement: step 7, image 3 of 3
    • Pry the battery up from the laptop using an opening pick.
    • Lift the battery out of its place.
  8. HP ProBook x360 11 G5 EE Speakers Replacement, Speakers: step 8, image 1 of 2 HP ProBook x360 11 G5 EE Speakers Replacement, Speakers: step 8, image 2 of 2
    • Remove the four 5 mm screws holding the speakers in place using a JIS #0 screwdriver.
  9. HP ProBook x360 11 G5 EE Speakers Replacement: step 9, image 1 of 2 HP ProBook x360 11 G5 EE Speakers Replacement: step 9, image 2 of 2
    • Disconnect the speaker wire from its socket on the motherboard.
  10. HP ProBook x360 11 G5 EE Speakers Replacement: step 10, image 1 of 3 HP ProBook x360 11 G5 EE Speakers Replacement: step 10, image 2 of 3 HP ProBook x360 11 G5 EE Speakers Replacement: step 10, image 3 of 3
    • Remove the left speaker gently.
    • Remove the cable that connects both speakers together from the notches that hold it in place. Be careful when pulling the wire to avoid damaging it.
    • Remove the right speaker gently.
Michelle Pina
506 Reputation
4 Guides authored
Gateway, Team 1-4, Pee Fall 2021 Member of Gateway, Team 1-4, Pee Fall 2021
GCC-PEE-F21S1G4
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 21
All Time: 523
