Introduction
The guide will show how to replace the wireless card in your HP ProBook x360 11 G5 EE laptop. The Wi-Fi card allows you to connect to the internet wirelessly. If the laptop’s Wi-Fi keeps on connecting and disconnecting, has a weak connection, or simply cannot find any networks regardless of troubleshooting, you may have a faulty wireless card.
Remove the 4.1 mm screws with a T5 Torx screwdriver.
Remove the 4.1 mm screws using a JIS #0 screwdriver.
Disconnect the ribbon wire from the motherboard by lifting the small flap that holds it in place.
