HP ProOne 600 G1 Solid State Drive Replacement
  1. HP ProOne 600 G1 Solid State Drive Replacement, Solid State Drive: step 1, image 1 of 2 HP ProOne 600 G1 Solid State Drive Replacement, Solid State Drive: step 1, image 2 of 2
    • Push the unlock tabs on the back of the monitor in and towards each other while sliding the back cover up.
  2. HP ProOne 600 G1 Solid State Drive Replacement: step 2, image 1 of 1
    • Pull up on the hard drive bay handle and push it to the left while holding back the metal tab on the bottom.
  3. HP ProOne 600 G1 Solid State Drive Replacement: step 3, image 1 of 1
    • Pull side latch out and slide the hard drive tray out of the bay.
  4. HP ProOne 600 G1 Solid State Drive Replacement: step 4, image 1 of 2 HP ProOne 600 G1 Solid State Drive Replacement: step 4, image 2 of 2
    • Remove the four 5/16" side screws, with the T15 Torx Screwdriver, and gently take out the drive.
2 other people completed this guide.
Attached Documents
Janelle Layman
258 Reputation
2 Guides authored
Cal Poly, Team 1-20, Maness Fall 2015 Member of Cal Poly, Team 1-20, Maness Fall 2015
CPSU-MANESS-F15S1G20
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 74
All Time: 7,300
