HP Slate 7 Extreme 4400US Charging port and Audio Jack Circuit Board Replacement
  1. HP Slate 7 Extreme 4400US Charging port and Audio Jack Circuit Board Replacement, Back Cover: step 1, image 1 of 3 HP Slate 7 Extreme 4400US Charging port and Audio Jack Circuit Board Replacement, Back Cover: step 1, image 2 of 3 HP Slate 7 Extreme 4400US Charging port and Audio Jack Circuit Board Replacement, Back Cover: step 1, image 3 of 3
    • Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
    • Once all sides have been pried up, pull the cover off and place it to the side.
  2. HP Slate 7 Extreme 4400US Charging port and Audio Jack Circuit Board Replacement, Charging port and Audio Jack Circuit Board: step 2, image 1 of 2 HP Slate 7 Extreme 4400US Charging port and Audio Jack Circuit Board Replacement, Charging port and Audio Jack Circuit Board: step 2, image 2 of 2
    • Use the PH #000 phillips head screw driver to remove one 5.0 mm screw.
    • Move plastic housing and rear facing camera to expose silver bracket.
  3. HP Slate 7 Extreme 4400US Charging port and Audio Jack Circuit Board Replacement: step 3, image 1 of 2 HP Slate 7 Extreme 4400US Charging port and Audio Jack Circuit Board Replacement: step 3, image 2 of 2
    • Use the PH #000 phillips head screw driver to remove three 3.0mm screws. Remove the silver bracket.
  4. HP Slate 7 Extreme 4400US Charging port and Audio Jack Circuit Board Replacement: step 4, image 1 of 3 HP Slate 7 Extreme 4400US Charging port and Audio Jack Circuit Board Replacement: step 4, image 2 of 3 HP Slate 7 Extreme 4400US Charging port and Audio Jack Circuit Board Replacement: step 4, image 3 of 3
    • Use the nylon spudger to flip up the black retaining flap of the zero insertion force (ZIF) connector holding the strip in place.
    • Grab the green circuit board and pull directly up to separate the glued down power strip.
    • Gently pull the circuit board out of its connector.
Brandon Ko
698 Reputation
6 Guides authored
USF Tampa, Team 11-4, Blackwell Fall 2016 Member of USF Tampa, Team 11-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G4
4 Members
16 Guides authored
5 Comments
where can i get the part at?
cat jones - Reply
Where do you even get the part at??
Mountiansurfer Gaming - Reply
Where do I even get the part at???
Can you let us know where to get the replacement part from?
ypk77 - Reply
This is completely useless information without a source for the shoddy HP part!
Brian Burke - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 19
All Time: 2,019
