HP Slate 7 Extreme 4400US Front-facing Camera Replacement
  1. HP Slate 7 Extreme 4400US Front-facing Camera Replacement, Back Cover: step 1, image 1 of 3 HP Slate 7 Extreme 4400US Front-facing Camera Replacement, Back Cover: step 1, image 2 of 3 HP Slate 7 Extreme 4400US Front-facing Camera Replacement, Back Cover: step 1, image 3 of 3
    • Use the plastic opening tool to separate the back cover from the tablet. Carefully use the tool to pry open the sides, going around the entire tablet to lift the sides up.
    • Once all sides have been pried up, pull the cover off and place it to the side.
  2. HP Slate 7 Extreme 4400US Front-facing Camera Replacement, Front-facing Camera: step 2, image 1 of 2 HP Slate 7 Extreme 4400US Front-facing Camera Replacement, Front-facing Camera: step 2, image 2 of 2
    • Use the PH #000 screw bit to remove the 5.0 mm screw holding down the top speaker to expose the front-facing camera.
  3. HP Slate 7 Extreme 4400US Front-facing Camera Replacement: step 3, image 1 of 3 HP Slate 7 Extreme 4400US Front-facing Camera Replacement: step 3, image 2 of 3 HP Slate 7 Extreme 4400US Front-facing Camera Replacement: step 3, image 3 of 3
    • Pull back the tape holding the the front facing camera's connector strip to the device.
    • Use the nylon spudger to flip up the black retaining flap of the zero insertion force (ZIF) connector holding the strip in place.
    • Gently pull the camera's connecting strip out from the port.
Brandon Ko
698 Reputation
6 Guides authored
USF Tampa, Team 11-4, Blackwell Fall 2016 Member of USF Tampa, Team 11-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G4
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 16
All Time: 157
