HP Slate 8 Pro Antenna Replacement
  1. HP Slate 8 Pro Antenna Replacement, Remove the back cover: step 1, image 1 of 1
    • Use plastic tool to remove the back cover.
  2. HP Slate 8 Pro Antenna Replacement, Detach Wi-Fi cable from clips: step 2, image 1 of 1
    • Release the Wi-Fi antenna cable from the routing clips and channel from the main board.
  3. HP Slate 8 Pro Antenna Replacement, Detach the WI-FI antenna: step 3, image 1 of 1
    • Detach the Wi-Fi antenna from the main board.
  4. HP Slate 8 Pro Antenna Replacement, Detach Wi-Fi antenna from panel assembly.: step 4, image 1 of 1
    • Detach the Wi-Fi antenna transceiver from the display panel assembly that is attached with adhesive.
Jose Revelo
305 Reputation
3 Guides authored
USF Tampa, Team 9-4, Blackwell Fall 2014 Member of USF Tampa, Team 9-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G4
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 9
All Time: 655
