HP Slate 8 Pro Battery Replacement
  1. HP Slate 8 Pro Battery Replacement, Remove Back Panel: step 1, image 1 of 2 HP Slate 8 Pro Battery Replacement, Remove Back Panel: step 1, image 2 of 2
    • Secure the suction cup to the center of the device’s screen.
    • Begin to pull upwards with the suction cup. While pulling, start easing the plastic opening tool into the space between the screen and the device. This will gradually separate the screen from the plastic back panel.
  2. HP Slate 8 Pro Battery Replacement, Remove yellow cables: step 2, image 1 of 2 HP Slate 8 Pro Battery Replacement, Remove yellow cables: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Use a spudger tool to release the black clips on the two connectors holding the flat, yellow cable in place.
    • Use the tweezers to pull the flat, yellow cable out of its connectors.
    • Use the tweezers to disconnect the battery connector from the circuit board.
    • Using the spudger tool again, pry up and release the connectors at the ends of the flat, orange cable.
    • Remove the flat, orange cable.
  3. HP Slate 8 Pro Battery Replacement, Remove Screws Around Battery: step 3, image 1 of 1
    • As shown, the battery is held in place by a total of 8 screws. Use the #00 Phillips screwdriver to remove all 8.
  4. HP Slate 8 Pro Battery Replacement, Lift Battery out of Device: step 4, image 1 of 1
    • Grasp the battery and remove it from the device.
    • Do not attempt to open or tamper with the battery. This could result in injury.
2 other people completed this guide.
Jose Revelo
308 Reputation
3 Guides authored
USF Tampa, Team 9-4, Blackwell Fall 2014 Member of USF Tampa, Team 9-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G4
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 9
All Time: 3,421
