HP Slate 8 Pro Front Facing Camera Replacement
  1. HP Slate 8 Pro Front Facing Camera Replacement, Front Facing Camera: step 1, image 1 of 2 HP Slate 8 Pro Front Facing Camera Replacement, Front Facing Camera: step 1, image 2 of 2
    • Secure the suction cup to the center of the screen.
    • Using a plastic opening tool, pry along the edges of the display while pulling upwards with the suction cup.
  2. HP Slate 8 Pro Front Facing Camera Replacement: step 2, image 1 of 1
    • Use the Spudger to disconnect the ribbon cable to the upper camera by prying the connector away from the board.
  3. HP Slate 8 Pro Front Facing Camera Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Use ESD safe tweezers to pry the camera away from the motherboard starting at the side opposite the ribbon cable.
Andrew Hall
322 Reputation
3 Guides authored
IUPUI, Team 1-4, Renguette SU 2016 Member of IUPUI, Team 1-4, Renguette SU 2016
IUPUI-RENGUETTE-SU16S1G4
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 280
