HP Slate 8 Pro IO Board Replacement
  1. HP Slate 8 Pro IO Board Replacement, Remove back cover: step 1, image 1 of 1
    • Turn off the tablet. If you are unsure whether the tablet is off or in Hibernation, turn the tablet on, and then shut it down
    • Remove the back cover.
  2. HP Slate 8 Pro IO Board Replacement, Disconnect battery cable: step 2, image 1 of 1
    • Disconnect the battery cable from the system board
  3. HP Slate 8 Pro IO Board Replacement, Remove ribbon cables: step 3, image 1 of 1
    • Pull the yellow ribbons
  4. HP Slate 8 Pro IO Board Replacement, Disconnect speaker cables: step 4, image 1 of 1
    • Disconnect the speaker cables from the I/O board
  5. HP Slate 8 Pro IO Board Replacement, Remove screws: step 5, image 1 of 1
    • Remove the two Phillips PM1.5×4.0 screws that secure the I/O board to the display panel assembly.
  6. HP Slate 8 Pro IO Board Replacement, Remove the IO board: step 6, image 1 of 1
    • Remove the IO board carefully.
Claudia
246 Reputation
2 Guides authored
USF Tampa, Team 9-4, Blackwell Fall 2014 Member of USF Tampa, Team 9-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G4
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 8
All Time: 847
