HP Slate 8 Pro Speakers Replacement
  1. HP Slate 8 Pro Speakers Replacement, Remove back cover: step 1, image 1 of 1
    • Use plastic opening tool to pry back panel off.
  2. HP Slate 8 Pro Speakers Replacement, Detach IO Board from system: step 2, image 1 of 2 HP Slate 8 Pro Speakers Replacement, Detach IO Board from system: step 2, image 2 of 2
    • Remove the orange and yellow ribbon cables.
    • detach the screws along the IO board
  3. HP Slate 8 Pro Speakers Replacement, Remove the IO board and the speakers: step 3, image 1 of 1
    • Remove the IO board and the speakers circuit. Note that they are held together.
  4. HP Slate 8 Pro Speakers Replacement, Detach the speakers from the IO board.: step 4, image 1 of 1
    • The tablet has two speakers. Each speaker is located to both sides of the IO board.
    • Detach the speakers from the cables that connect the speakers and the IO board. You will find more details in step 5 and 6.
  5. HP Slate 8 Pro Speakers Replacement, Remove the wires of the speakers from the IO board.: step 5, image 1 of 1
    • To remove the cables that connect the speakers and the IO board, apply a subtle pressure to pull the cable out.
  6. HP Slate 8 Pro Speakers Replacement, Replace your speakers with the new parts: step 6, image 1 of 2 HP Slate 8 Pro Speakers Replacement, Replace your speakers with the new parts: step 6, image 2 of 2
    • Once you detach the speakers from the IO board, you should have three pieces as shown.
    • You are ready to replace the speakers.
Jose Revelo
305 Reputation
3 Guides authored
USF Tampa, Team 9-4, Blackwell Fall 2014 Member of USF Tampa, Team 9-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G4
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 7
All Time: 443
