HP Spectre 13-4002dx Battery Replacement
  1. HP Spectre 13-4002dx Battery Replacement, Bottom Case: step 1, image 1 of 2 HP Spectre 13-4002dx Battery Replacement, Bottom Case: step 1, image 2 of 2
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx Battery Replacement: step 2, image 1 of 2 HP Spectre 13-4002dx Battery Replacement: step 2, image 2 of 2
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx Battery Replacement, Battery: step 3, image 1 of 3 HP Spectre 13-4002dx Battery Replacement, Battery: step 3, image 2 of 3 HP Spectre 13-4002dx Battery Replacement, Battery: step 3, image 3 of 3
    • Orient the laptop the same way as the pictures. The battery is bordered in a red outline.
    • Remove the six 4 mm screws using a Phillips #000 screwdriver.
  4. HP Spectre 13-4002dx Battery Replacement: step 4, image 1 of 3 HP Spectre 13-4002dx Battery Replacement: step 4, image 2 of 3 HP Spectre 13-4002dx Battery Replacement: step 4, image 3 of 3
    • Do not disconnect the cable connector shown in the red box.
    • The speaker cable may be attached to the battery with black electrical tape. If so, remove the tape.
    • Move the cable clear of the battery.
  5. HP Spectre 13-4002dx Battery Replacement: step 5, image 1 of 2 HP Spectre 13-4002dx Battery Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Do not disconnect the cable connector located in the red box.
    • Use tweezers to remove the speaker cable from the groove attached to the battery.
    • Push the cable to the side so it does not get in the way of the battery removal.
  6. HP Spectre 13-4002dx Battery Replacement: step 6, image 1 of 3 HP Spectre 13-4002dx Battery Replacement: step 6, image 2 of 3 HP Spectre 13-4002dx Battery Replacement: step 6, image 3 of 3
    • Disconnect the battery cable connector by sliding it out of the socket.
    • Move the battery out of the way if you need more room to disconnect the power cable.
  7. HP Spectre 13-4002dx Battery Replacement: step 7, image 1 of 1
    • Carefully remove the battery.
0 Comments
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 25
All Time: 1,270
