HP Spectre 13-4002dx Heat Sink Replacement
  1. HP Spectre 13-4002dx Heat Sink Replacement, Bottom Case: step 1, image 1 of 2 HP Spectre 13-4002dx Heat Sink Replacement, Bottom Case: step 1, image 2 of 2
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx Heat Sink Replacement: step 2, image 1 of 2 HP Spectre 13-4002dx Heat Sink Replacement: step 2, image 2 of 2
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx Heat Sink Replacement, Heat Sink: step 3, image 1 of 3 HP Spectre 13-4002dx Heat Sink Replacement, Heat Sink: step 3, image 2 of 3 HP Spectre 13-4002dx Heat Sink Replacement, Heat Sink: step 3, image 3 of 3
    • Remove the tape outlined in red.
    • The tape can tear easily.
  4. HP Spectre 13-4002dx Heat Sink Replacement: step 4, image 1 of 2 HP Spectre 13-4002dx Heat Sink Replacement: step 4, image 2 of 2
    • Remove the four 3 mm screws using a Phillips #0 screwdriver.
  5. HP Spectre 13-4002dx Heat Sink Replacement: step 5, image 1 of 1
    • Remove the heat sink from the laptop.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 271
