HP Spectre 13-4002dx Vent Fan Replacement
  1. HP Spectre 13-4002dx Vent Fan Replacement, Bottom Case: step 1, image 1 of 2 HP Spectre 13-4002dx Vent Fan Replacement, Bottom Case: step 1, image 2 of 2
    • Using the Torx T5 screwdriver, remove the eight 8 mm screws on the bottom case of the laptop.
  2. HP Spectre 13-4002dx Vent Fan Replacement: step 2, image 1 of 2 HP Spectre 13-4002dx Vent Fan Replacement: step 2, image 2 of 2
    • Pry up one corner of the bottom case with a spudger.
    • Work the spudger around the edges, making your way towards the bottom of the laptop.
    • Remove the bottom case.
  3. HP Spectre 13-4002dx Vent Fan Replacement, Vent Fan: step 3, image 1 of 3 HP Spectre 13-4002dx Vent Fan Replacement, Vent Fan: step 3, image 2 of 3 HP Spectre 13-4002dx Vent Fan Replacement, Vent Fan: step 3, image 3 of 3
    • Remove the strip of black electrical tape.
    • Pull the tape away from the vent fan.
    • Pull gently, as the tape is easy to rip.
  4. HP Spectre 13-4002dx Vent Fan Replacement: step 4, image 1 of 2 HP Spectre 13-4002dx Vent Fan Replacement: step 4, image 2 of 2
    • Using a Phillips #0 screwdriver, remove the two 40 mm screws securing the fan assembly to the motherboard.
  5. HP Spectre 13-4002dx Vent Fan Replacement: step 5, image 1 of 3 HP Spectre 13-4002dx Vent Fan Replacement: step 5, image 2 of 3 HP Spectre 13-4002dx Vent Fan Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Using tweezers, disconnect the wire connection between the laptop and the vent fan.
  6. HP Spectre 13-4002dx Vent Fan Replacement: step 6, image 1 of 1
    • Remove the vent fan.
One Comment
Any idea what model# the fan is?
ayekay - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 287
