HP Spectre x360 13-ac023dx Motherboard Replacement
Jonathan
Jonathan and 3 other contributors
Last updated on October 1, 2024
15 minutes
Moderate
Better Introduction
Introduction
Go to step 1
If your HP Spectre x360 13-ac023dx laptop will not boot up after troubleshooting possibles errors, use this motherboard replacement guide.
Tools
Show more…
  1. HP Spectre x360 13-ac023dx Motherboard Replacement, Battery: step 1, image 1 of 2 HP Spectre x360 13-ac023dx Motherboard Replacement, Battery: step 1, image 2 of 2
    • Flip the laptop over so the model sticker faces the ceiling.
  2. HP Spectre x360 13-ac023dx Motherboard Replacement: step 2, image 1 of 3 HP Spectre x360 13-ac023dx Motherboard Replacement: step 2, image 2 of 3 HP Spectre x360 13-ac023dx Motherboard Replacement: step 2, image 3 of 3
    • Use a Torx #5 screwdriver to remove the six 3.5 mm screws holding the back cover to the laptop.
  3. HP Spectre x360 13-ac023dx Motherboard Replacement: step 3, image 1 of 2 HP Spectre x360 13-ac023dx Motherboard Replacement: step 3, image 2 of 2
    • Use the Phillips #000 screwdriver to remove the four 3.5 mm screws holding the battery.
    • After removing the screws, detach the battery wire from the mother board with the iFixit opening tool.
    • Then, carefully lift the battery off with the iFixit opening tool.
  4. HP Spectre x360 13-ac023dx Motherboard Replacement, Fan: step 4, image 1 of 1
    • Locate the Cooling Fan in the device.
  5. HP Spectre x360 13-ac023dx Motherboard Replacement: step 5, image 1 of 2 HP Spectre x360 13-ac023dx Motherboard Replacement: step 5, image 2 of 2
    • Use the Phillips #000 screwdriver to remove the 3mm screws holding the fan in place.
    • Remove the wires connecting to the motherboard, using the iFixit opening tool.
    • The iFixit Opening Tool is not required, but recommended
  6. HP Spectre x360 13-ac023dx Motherboard Replacement: step 6, image 1 of 1
    • Remove the Cooling Fan.
  7. HP Spectre x360 13-ac023dx Motherboard Replacement, WiFi Card: step 7, image 1 of 1
    • Locate the WiFi card in the top left of the motherboard.
  8. HP Spectre x360 13-ac023dx Motherboard Replacement: step 8, image 1 of 1
    • Use the Phillips #000 screwdriver to remove the screw holding the wifi card in place.
  9. HP Spectre x360 13-ac023dx Motherboard Replacement: step 9, image 1 of 2 HP Spectre x360 13-ac023dx Motherboard Replacement: step 9, image 2 of 2
    • Once the screw is removed, hold the WiFi card by it's sides and raise it up whiling sliding it out from the slot.
  10. HP Spectre x360 13-ac023dx Motherboard Replacement: step 10, image 1 of 1
    • After removing the Wifi card, place the card within a static dissipative bag.
  11. HP Spectre x360 13-ac023dx Motherboard Replacement: step 11, image 1 of 1
    • Hold the replacement Wifi card by the edges and remove it out of the static-dissipative bag.
  12. HP Spectre x360 13-ac023dx Motherboard Replacement: step 12, image 1 of 1
    • Align the notches on the Wifi card with the keys on the Wifi card slot.
    • Hold the card by the edges and slide the Wifi card into the Wifi Card slot.
  13. HP Spectre x360 13-ac023dx Motherboard Replacement: step 13, image 1 of 1
    • Use the Phillips #000 screwdriver to attach the screw holding the Wifi card in place.
  14. HP Spectre x360 13-ac023dx Motherboard Replacement, Motherboard: step 14, image 1 of 1
    • Ensure that all other components which were previously removed are not longer attached.
  15. HP Spectre x360 13-ac023dx Motherboard Replacement: step 15, image 1 of 3 HP Spectre x360 13-ac023dx Motherboard Replacement: step 15, image 2 of 3 HP Spectre x360 13-ac023dx Motherboard Replacement: step 15, image 3 of 3
    • Disconnect the wires which connect the motherboard to the rest of the components.
    • The black and red wire can be removed by pulling the wire upwards.
  16. HP Spectre x360 13-ac023dx Motherboard Replacement: step 16, image 1 of 3 HP Spectre x360 13-ac023dx Motherboard Replacement: step 16, image 2 of 3 HP Spectre x360 13-ac023dx Motherboard Replacement: step 16, image 3 of 3
    • Use the Phillips #000 screwdriver to remove the three 3.5 mm screws which keep the motherboard in place.
  17. HP Spectre x360 13-ac023dx Motherboard Replacement: step 17, image 1 of 2 HP Spectre x360 13-ac023dx Motherboard Replacement: step 17, image 2 of 2
    • Carefully lift and remove the motherboard.
Jonathan
498 Reputation
4 Guides authored
One Comment
Can I get ho spectre x360 motherboard to buy from your end?
Immanuel - Reply
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 54
All Time: 3,827
