HP Spectre x360 13t-4000 SD Card Reader Replacement
  1. HP Spectre x360 13t-4000 SD Card Reader Replacement, Bottom Cover: step 1, image 1 of 2 HP Spectre x360 13t-4000 SD Card Reader Replacement, Bottom Cover: step 1, image 2 of 2
    • Turn off and unplug the laptop.
    • Flip over the laptop so that the bottom backplate is exposed.
  2. HP Spectre x360 13t-4000 SD Card Reader Replacement: step 2, image 1 of 2 HP Spectre x360 13t-4000 SD Card Reader Replacement: step 2, image 2 of 2
    • Use a T5 screwdriver to remove the six 3 mm screws that secure the backplate.
    • Use the same screwdriver to remove the two 7 mm screws.
  3. HP Spectre x360 13t-4000 SD Card Reader Replacement: step 3, image 1 of 3 HP Spectre x360 13t-4000 SD Card Reader Replacement: step 3, image 2 of 3 HP Spectre x360 13t-4000 SD Card Reader Replacement: step 3, image 3 of 3
    • Insert an opening tool under the bottom cover at the screen hinges, and gently pry the cover free.
    • Carefully work your way around the cover's edges to pop it off completely.
  4. HP Spectre x360 13t-4000 SD Card Reader Replacement, Battery: step 4, image 1 of 3 HP Spectre x360 13t-4000 SD Card Reader Replacement, Battery: step 4, image 2 of 3 HP Spectre x360 13t-4000 SD Card Reader Replacement, Battery: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • With the backplate removed, remove the four 3 mm screws securing the battery with a Phillips #1 screwdriver.
    • With the screws removed, disconnect the 3 wires connected to the battery.
    • Tweezers may be needed to remove the wires.
  5. HP Spectre x360 13t-4000 SD Card Reader Replacement, SD Card Reader: step 5, image 1 of 2 HP Spectre x360 13t-4000 SD Card Reader Replacement, SD Card Reader: step 5, image 2 of 2
    • Remove the 2 mm long Phillips #000 head screw on the SD Card Reader.
    • Using a plastic spudger, release the pressure connector marked with the green rectangle by gently prying up from below.
    • Once the pressure connector is undone, the white ribbon cable connected to the SD Card Reader will pull out with no resistance.
    • With the ribbon cable disconnected and the screw out, the SD Card Reader will be free to remove and replace.
    • When replacing the SD Card Reader, ensure the ribbon cable is firmly secured in the pressure connector, with the metal contact points facing down towards the motherboard.
Brandon Carvalho
566 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 20
All Time: 717
