HP Spectre x360 13t-4000 Wifi Adapter Replacement
  1. HP Spectre x360 13t-4000 Wifi Adapter Replacement, Bottom Cover: step 1, image 1 of 2 HP Spectre x360 13t-4000 Wifi Adapter Replacement, Bottom Cover: step 1, image 2 of 2
    • Turn off and unplug the laptop.
    • Flip over the laptop so that the bottom backplate is exposed.
  2. HP Spectre x360 13t-4000 Wifi Adapter Replacement: step 2, image 1 of 2 HP Spectre x360 13t-4000 Wifi Adapter Replacement: step 2, image 2 of 2
    • Use a T5 screwdriver to remove the six 3 mm screws that secure the backplate.
    • Use the same screwdriver to remove the two 7 mm screws.
  3. HP Spectre x360 13t-4000 Wifi Adapter Replacement: step 3, image 1 of 3 HP Spectre x360 13t-4000 Wifi Adapter Replacement: step 3, image 2 of 3 HP Spectre x360 13t-4000 Wifi Adapter Replacement: step 3, image 3 of 3
    • Insert an opening tool under the bottom cover at the screen hinges, and gently pry the cover free.
    • Carefully work your way around the cover's edges to pop it off completely.
  4. HP Spectre x360 13t-4000 Wifi Adapter Replacement, Battery: step 4, image 1 of 3 HP Spectre x360 13t-4000 Wifi Adapter Replacement, Battery: step 4, image 2 of 3 HP Spectre x360 13t-4000 Wifi Adapter Replacement, Battery: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • With the backplate removed, remove the four 3 mm screws securing the battery with a Phillips #1 screwdriver.
    • With the screws removed, disconnect the 3 wires connected to the battery.
    • Tweezers may be needed to remove the wires.
  5. HP Spectre x360 13t-4000 Wifi Adapter Replacement, Wifi Adapter: step 5, image 1 of 3 HP Spectre x360 13t-4000 Wifi Adapter Replacement, Wifi Adapter: step 5, image 2 of 3 HP Spectre x360 13t-4000 Wifi Adapter Replacement, Wifi Adapter: step 5, image 3 of 3
    Buy
    • Using a Phillips#0 screwdriver, remove the 2 mm screw.
    • Located to the right of the screw, there are two wires connected to the adapter. Using tweezers, carefully remove the wires.
    • There may be tape covering the wires.
    • Now you can remove the adapter by pulling it from its socket.
Brandon Carvalho
566 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 951
