HP Spectre x360 15" (15t-ap000) Back Cover Replacement
  1. HP Spectre x360 15" (15t-ap000) Back Cover Replacement, Unscrew the back cover: step 1, image 1 of 1
    • Be sure to completely power off and unplug your laptop before you begin your repair. Make sure the laptop is not in standby, sleep, or hibernation mode.
    • Use a T5 driver to remove the following screws securing the back cover:
    • Six 4 mm-long screws
    • Two 7.8 mm-long screws
  2. HP Spectre x360 15" (15t-ap000) Back Cover Replacement, Loosen the back cover: step 2, image 1 of 2 HP Spectre x360 15" (15t-ap000) Back Cover Replacement, Loosen the back cover: step 2, image 2 of 2
    • Use an opening tool or your fingers to pry up the back cover from the laptop.
    • Plastic clips hold the back cover lightly in place, so you may encounter some resistance.
    • If it feels like there is strong resistance, you may have a model that includes screws under the corner feet. Carefully pry the feet up to make sure they don't have screws.
  3. HP Spectre x360 15" (15t-ap000) Back Cover Replacement, Remove the back cover: step 3, image 1 of 2 HP Spectre x360 15" (15t-ap000) Back Cover Replacement, Remove the back cover: step 3, image 2 of 2
    • Lift and remove the back cover.
    • During reassembly, gently press along the perimeter of the back cover to re-engage the clips.
Arthur Shi
258,916 Reputation
531 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,078 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 51
All Time: 2,471
