HP Spectre x360 15" (15t-ap000) Battery Replacement
  1. HP Spectre x360 15" (15t-ap000) Battery Replacement, Unscrew the back cover: step 1, image 1 of 1
    • Be sure to completely power off and unplug your laptop before you begin your repair. Make sure the laptop is not in standby, sleep, or hibernation mode.
    • Use a T5 driver to remove the following screws securing the back cover:
    • Six 4 mm-long screws
    • Two 7.8 mm-long screws
  2. HP Spectre x360 15" (15t-ap000) Battery Replacement, Loosen the back cover: step 2, image 1 of 2 HP Spectre x360 15" (15t-ap000) Battery Replacement, Loosen the back cover: step 2, image 2 of 2
    • Use an opening tool or your fingers to pry up the back cover from the laptop.
    • Plastic clips hold the back cover lightly in place, so you may encounter some resistance.
    • If it feels like there is strong resistance, you may have a model that includes screws under the corner feet. Carefully pry the feet up to make sure they don't have screws.
  3. HP Spectre x360 15" (15t-ap000) Battery Replacement, Remove the back cover: step 3, image 1 of 2 HP Spectre x360 15" (15t-ap000) Battery Replacement, Remove the back cover: step 3, image 2 of 2
    • Lift and remove the back cover.
    • During reassembly, gently press along the perimeter of the back cover to re-engage the clips.
  4. HP Spectre x360 15" (15t-ap000) Battery Replacement, Disconnect the battery: step 4, image 1 of 3 HP Spectre x360 15" (15t-ap000) Battery Replacement, Disconnect the battery: step 4, image 2 of 3 HP Spectre x360 15" (15t-ap000) Battery Replacement, Disconnect the battery: step 4, image 3 of 3
    • Pry the edges of the battery connector with a spudger to loosen the connector from its motherboard socket.
    • Gently pull the connector parallel to the motherboard to disconnect it.
  5. HP Spectre x360 15" (15t-ap000) Battery Replacement, Remove the battery: step 5, image 1 of 1
    • Use a Phillips screwdriver to remove the five 4.3 mm-long screws securing the battery to the laptop.
  6. HP Spectre x360 15" (15t-ap000) Battery Replacement: step 6, image 1 of 2 HP Spectre x360 15" (15t-ap000) Battery Replacement: step 6, image 2 of 2
    • Lift and remove the battery from the laptop.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Arthur Shi
258,916 Reputation
531 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,078 Guides authored
4 Comments
I have the same model, but there are screws under the two rear rubber feet. I damaged one of the feet during removal ):
Miguel Medina - Reply
I'm sorry to hear that! I double-checked my laptop, and it doesn't have the two feet. Perhaps there was a hardware update. I'll add a note in the guides.
Arthur Shi -
So the battery shown/listed in the store is a PK03XL but the images (and my laptop) clearly have the PG03XL model which has higher amp hours. Also, the PK0 does not fit.
Karim T - Reply
Hi Karim,
That's correct! The PK03XL battery that's sold in the iFixit store is for the 13" HP Spectre. This guide is written for the 15" HP Spectre.
Arthur Shi -
Past 24 Hours: 0
Past 7 Days: 16
Past 30 Days: 104
All Time: 7,235
