HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement
  1. HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement, Unscrew the back cover: step 1, image 1 of 1
    • Be sure to completely power off and unplug your laptop before you begin your repair. Make sure the laptop is not in standby, sleep, or hibernation mode.
    • Use a T5 driver to remove the following screws securing the back cover:
    • Six 4 mm-long screws
    • Two 7.8 mm-long screws
  2. HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement, Loosen the back cover: step 2, image 1 of 2 HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement, Loosen the back cover: step 2, image 2 of 2
    • Use an opening tool or your fingers to pry up the back cover from the laptop.
    • Plastic clips hold the back cover lightly in place, so you may encounter some resistance.
    • If it feels like there is strong resistance, you may have a model that includes screws under the corner feet. Carefully pry the feet up to make sure they don't have screws.
  3. HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement, Remove the back cover: step 3, image 1 of 2 HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement, Remove the back cover: step 3, image 2 of 2
    • Lift and remove the back cover.
    • During reassembly, gently press along the perimeter of the back cover to re-engage the clips.
  4. HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement, Disconnect the battery: step 4, image 1 of 3 HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement, Disconnect the battery: step 4, image 2 of 3 HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement, Disconnect the battery: step 4, image 3 of 3
    • Pry the edges of the battery connector with a spudger to loosen the connector from its motherboard socket.
    • Gently pull the connector parallel to the motherboard to disconnect it.
  5. HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement, Remove the Wi-Fi card: step 5, image 1 of 2 HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement, Remove the Wi-Fi card: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Use your fingers or tweezers to peel the black plastic strip until you uncover the Wi-Fi card.
  6. HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement: step 6, image 1 of 3 HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement: step 6, image 2 of 3 HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement: step 6, image 3 of 3
    • Use the point of a spudger to carefully pry up and disconnect the two antenna cables from the Wi-Fi card.
  7. HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement: step 7, image 1 of 1
    • Use a Phillips screwdriver to remove the 2.8 mm-long screw securing the Wi-Fi card to the motherboard.
  8. HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement: step 8, image 1 of 2 HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement: step 8, image 2 of 2
    • Grasp the Wi-Fi card edges with your fingers and pull it at a shallow angle parallel to the motherboard.
    • Remove the Wi-Fi card.
Arthur Shi
258,916 Reputation
531 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,078 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 44
All Time: 1,708
