HP Spectre x360 15-bl012dx Battery Replacement
  1. HP Spectre x360 15-bl012dx Battery Replacement, Battery Replacement: step 1, image 1 of 2 HP Spectre x360 15-bl012dx Battery Replacement, Battery Replacement: step 1, image 2 of 2
    • Power off the device before beginning disassembly.
    • Place the computer so that the back panel is facing up. Begin by removing the two visible Torx T5 9 mm screws near the hinges.
    • Next, remove the four visible Torx T5 3 mm on the sides.
    • Keep track of all screws.
  2. HP Spectre x360 15-bl012dx Battery Replacement: step 2, image 1 of 3 HP Spectre x360 15-bl012dx Battery Replacement: step 2, image 2 of 3 HP Spectre x360 15-bl012dx Battery Replacement: step 2, image 3 of 3
    • Please note the upper two feet are already removed. The device was given to us this way.
    • Remove the two upper feet using an opening tool or spudger if they are still in place. The upper feet are closer to the hinges for the screen.
    • Remove the two 8 mm Phillips #1 screws under the feet.
    • These are the final screws to remove from the back panel. In total, you should remove eight screws between Steps 1 and 2.
  3. HP Spectre x360 15-bl012dx Battery Replacement: step 3, image 1 of 1
    • Use a spudger to pry the back panel off of the laptop. Work your way around the perimeter of the device to loosen the connection.
    • Take the back panel off of the laptop.
  4. HP Spectre x360 15-bl012dx Battery Replacement: step 4, image 1 of 1
    • Use a Phillips #1 screwdriver to remove six 4 mm screws securing the battery.
  5. HP Spectre x360 15-bl012dx Battery Replacement: step 5, image 1 of 3 HP Spectre x360 15-bl012dx Battery Replacement: step 5, image 2 of 3 HP Spectre x360 15-bl012dx Battery Replacement: step 5, image 3 of 3
    • Unplug the battery connector located on the motherboard.
    • Remove the battery from the laptop.
Peyton Stewart
282 Reputation
2 Guides authored
Clemson, Team 1-1, Hunter Spring 2022 Member of Clemson, Team 1-1, Hunter Spring 2022
CLEM-HUNTER-S22S1G1
5 Members
5 Guides authored
5 Comments
Great writeup. Any idea where I could get an OEM or OEM-quality replacement battery?
Ben - Reply
Excellent guidance, many thanks!
Brenda Mallinson - Reply
Thanks for the guide! Figured there were screws under the rear feet but this confirmed it and prevented me from doing something silly.
Nick Di Vona - Reply
Where are you guys finding replacement batteries from? I don't want to go through the process of buying and returning crappy batteries
Kisan Patel - Reply
Past 24 Hours: 1
Past 7 Days: 25
Past 30 Days: 83
All Time: 3,500
