HP Split x2 13-g210dx Docking Port Replacement
  1. HP Split x2 13-g210dx Docking Port Replacement, Back Panel: step 1, image 1 of 1
    • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
    • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
    • Remove the four 4-mm Phillips #0 screws.
    • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
    • You will hear popping noises as the clips separate from each other.
  2. HP Split x2 13-g210dx Docking Port Replacement, Battery: step 2, image 1 of 1
    • Remove the three 6-mm Phillips #0 screws.
  3. HP Split x2 13-g210dx Docking Port Replacement: step 3, image 1 of 2 HP Split x2 13-g210dx Docking Port Replacement: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the white connector clip from the connector port using a sturdy tweezers.
  4. HP Split x2 13-g210dx Docking Port Replacement: step 4, image 1 of 2 HP Split x2 13-g210dx Docking Port Replacement: step 4, image 2 of 2
    • Lift the battery away from the device.
  5. HP Split x2 13-g210dx Docking Port Replacement, Docking Port: step 5, image 1 of 1
    • Remove the two 4-mm Phillips #0 screws.
  6. HP Split x2 13-g210dx Docking Port Replacement: step 6, image 1 of 2 HP Split x2 13-g210dx Docking Port Replacement: step 6, image 2 of 2
    Buy
    • Remove the clips from the docking port board with a sturdy pair of tweezers.
  7. HP Split x2 13-g210dx Docking Port Replacement: step 7, image 1 of 2 HP Split x2 13-g210dx Docking Port Replacement: step 7, image 2 of 2
    • Remove the two ribbons labeled "Dock" at the top of the docking port board using tweezers or a sturdy plastic opening tool.
  8. HP Split x2 13-g210dx Docking Port Replacement: step 8, image 1 of 1
    • Lift the docking port away from the device.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 855
