HP Split x2 Rear Cover Replacement
  1. HP Split x2 Rear Cover Replacement, Rear Cover: step 1, image 1 of 1
    • Opening the device voids the manufacturer warranty.
    • Power down the HP Split x2 before beginning the repair
    • Separate the tablet from the keyboard by pushing the slider to the left and lifting the tablet from the keyboard.
  2. HP Split x2 Rear Cover Replacement: step 2, image 1 of 3 HP Split x2 Rear Cover Replacement: step 2, image 2 of 3 HP Split x2 Rear Cover Replacement: step 2, image 3 of 3
    • Remove the four white caps on the bottom edge of the tablet.
    • Use a tweezer to grasp white caps.
    • The white caps are easily lost. Store them in a secure place.
  3. HP Split x2 Rear Cover Replacement: step 3, image 1 of 1
    • Use a Phillips #000 screwdriver to remove the four 3mm screws.
  4. HP Split x2 Rear Cover Replacement: step 4, image 1 of 2 HP Split x2 Rear Cover Replacement: step 4, image 2 of 2
    • Use a plastic opening tool to pry the tabs on the top, left and right sides of the tablet.
    • Only the top and sides have tabs. Remove all tabs before lifting screen.
  5. HP Split x2 Rear Cover Replacement: step 5, image 1 of 2 HP Split x2 Rear Cover Replacement: step 5, image 2 of 2
    • Separate the cover and the screen.
    • Gently lift the screen out of the cover.
7 other people completed this guide.
Ricky Huitema
464 Reputation
2 Guides authored
Texas Tech, Team 22-5, Rauch Fall 2015 Member of Texas Tech, Team 22-5, Rauch Fall 2015
TTU-RAUCH-F15S22G5
3 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 4,163
