HP Stream 11-d008TU Power Button Replacement
  1. HP Stream 11-d008TU Power Button Replacement, Rubber Feet Removal: step 1, image 1 of 3 HP Stream 11-d008TU Power Button Replacement, Rubber Feet Removal: step 1, image 2 of 3 HP Stream 11-d008TU Power Button Replacement, Rubber Feet Removal: step 1, image 3 of 3
    • Use a prying tool to pry the 2 rubber feet off closest to the hinge of the device
    • Repeat this process for the other side of the device
    • The bottom rubber feet do not have hidden screws underneath them, and as such, they are unnecessary to remove
  2. HP Stream 11-d008TU Power Button Replacement, Screw removal: step 2, image 1 of 2 HP Stream 11-d008TU Power Button Replacement, Screw removal: step 2, image 2 of 2
    • Remove the 11x 5mm Phillips PH-0 screws (circled)
  3. HP Stream 11-d008TU Power Button Replacement, Keyboard Unclipping: step 3, image 1 of 3 HP Stream 11-d008TU Power Button Replacement, Keyboard Unclipping: step 3, image 2 of 3 HP Stream 11-d008TU Power Button Replacement, Keyboard Unclipping: step 3, image 3 of 3
    • Use your finger to pry the outer blue shell over the keyboard
    • Continue this process around the edges of the device
    • You may have to use a prying tool to pry the harder edges such as around the I/O ports
    • Do not lift the keyboard once all the clips are undone, as there are still various cables connected
  4. HP Stream 11-d008TU Power Button Replacement, Keyboard removal: step 4, image 1 of 3 HP Stream 11-d008TU Power Button Replacement, Keyboard removal: step 4, image 2 of 3 HP Stream 11-d008TU Power Button Replacement, Keyboard removal: step 4, image 3 of 3
    • Disconnect the power button connector by peeling back the protective tape, using your fingernail to flip the white retaining clip back, and pulling the ribbon cable out
    • Disconnect the touchpad connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Disconnect the keyboard connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Your keyboard assembly is now safe to remove
  5. HP Stream 11-d008TU Power Button Replacement, Connector removal: step 5, image 1 of 2 HP Stream 11-d008TU Power Button Replacement, Connector removal: step 5, image 2 of 2
    • Remove the power button connector from the power button by flipping the white tab up and pulling the ribbon cable out
  6. HP Stream 11-d008TU Power Button Replacement, Unscrew Button: step 6, image 1 of 3 HP Stream 11-d008TU Power Button Replacement, Unscrew Button: step 6, image 2 of 3 HP Stream 11-d008TU Power Button Replacement, Unscrew Button: step 6, image 3 of 3
    • Unscrew the two Philips PH0 2.5mm screws
  7. HP Stream 11-d008TU Power Button Replacement: step 7, image 1 of 3 HP Stream 11-d008TU Power Button Replacement: step 7, image 2 of 3 HP Stream 11-d008TU Power Button Replacement: step 7, image 3 of 3
    • Lift the power button out of the slot
Joel Taylor
1,346 Reputation
8 Guides authored
Australia Member of Australia
Community
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 18
All Time: 437
