HP Stream 11-r020nr Charging Port Replacement
Introduction
Go to step 1This guide will show the step by step process of disassembling the HP stream in order to remove and replace the charging port.
Turn off your HP Stream 11-r020nr by holding the power button down for 10 seconds.
Turn the device top down so the rubber feet are facing up.
Use a metal spudger to remove all the rubber feet off of the bottom of the device, including the small ones. There will be a total of 11 screws to remove.
