HP Stream 11-y010nr Keyboard Replacement
  1. HP Stream 11-y010nr Keyboard Replacement, Keyboard: step 1, image 1 of 3 HP Stream 11-y010nr Keyboard Replacement, Keyboard: step 1, image 2 of 3 HP Stream 11-y010nr Keyboard Replacement, Keyboard: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • Gently peel back the two rubber strips that cover the screws on backside of the computer with the needle nose tweezers.
    • Ensure the laptop is turned off.
  2. HP Stream 11-y010nr Keyboard Replacement: step 2, image 1 of 2 HP Stream 11-y010nr Keyboard Replacement: step 2, image 2 of 2
    • Unscrew the seven 0.4mm screws on the backside of the laptop with the Phillips #0 Screwdriver.
  3. HP Stream 11-y010nr Keyboard Replacement: step 3, image 1 of 2 HP Stream 11-y010nr Keyboard Replacement: step 3, image 2 of 2
    • Take the opening picks and push them into the seam between the keyboard and the laptop casing.
    • Go all the way around the laptop.
  4. HP Stream 11-y010nr Keyboard Replacement: step 4, image 1 of 1
    • Once the cover is loose enough, lift the keyboard up to expose the wiring beneath.
    • Be careful not to pull too hard or fast as there are ribbon cables attached to the keyboard and trackpad.
  5. HP Stream 11-y010nr Keyboard Replacement: step 5, image 1 of 3 HP Stream 11-y010nr Keyboard Replacement: step 5, image 2 of 3 HP Stream 11-y010nr Keyboard Replacement: step 5, image 3 of 3
    • Disconnect the three cables by lifting up on the locking tab of the ZIF connector and pulling the cables out with the needle nose tweezers.
    • Remove the keyboard.
To reassemble your device, follow these instructions.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 26
All Time: 789
