Introduction
Is your HP Stream 11-y010nr WiFi malfunctioning? Do you need to replace your WiFi card? First, ensure that the issue is not one of the common problems that can be resolved quickly by checking the troubleshooting page here:Â [ HP Stream 11-y010nr Troubleshooting | HP Stream 11-y010nr Troubleshooting]
This guide will take you through the process of getting to the WiFi card, removing it, replacing it and getting it back to how it was. When you are removing the WiFi card remember the placement of the wires as it is important for the operation of the WiFi card.
Prior to starting, ensure the laptop is powered off and is not going to interfere with the process.
Use your fingers or a spudger to pull the battery cable out from its connector.
To reassemble your device, follow these instructions in reverse order. Make sure that you put the wires on the Wifi card to the correct location. Each of the cables are numbered with the wifi card having the numbers next to each plug.
